Re: where to lock down a 6.4 cam???
[Re: HotRodDave]
#2601440
01/04/19 01:34 PM
01/04/19 01:34 PM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
I have post around here somewhere where I listed the Eagle cam as .519/490 that actually is for the BGE 6.4 the Eagle is the same as the pre Eagle .472/.460. I forget what the LSA is and Duration for both cams. I know that's not much help, I'll look back at my notes tonight when I get home, but I think I backed off 4 degrees from straight up when I 1st did my SRT cam in my old 5.7 Eagle.
Truth has no agenda, but those with an agenda make their own truth. Some of us are so open minded they only see their View
[Re: HotRodDave]
#2601481
01/04/19 02:32 PM
01/04/19 02:32 PM
Posts: 2,255 IL
furious70
IL
What's the tq loss look like on an eagle 5.7 with either the BGE or SRT cam?
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: HotRodDave]
#2601591
01/04/19 05:20 PM
01/04/19 05:20 PM
Posts: 2,255 IL
furious70
IL
good to know - I'm learning from all you guys as I try to map out whether I'm going to replace the turbo 383 in my 70 Fury with a 5.7 eagle/nag1 turbo and whether I want to build a 5.7 based turbo engine for my 69 coronet vs the 400 based engine I'd been planning. Sounds like for either of those the SRT cam would be ok, plenty of gears and rear gear in the Fury and the race car of course wants the bigger cam.
[Re: furious70]
#2608848
01/19/19 01:23 AM
01/19/19 01:23 AM
Posts: 180 merrill, wisconsin
voigtspeed
merrill, wisconsin
We put a SRT 6.4 cam in my sons 2011 300 left cam phaser stock put it in stock motor is 11.3 compression forged wiesco pistons K1 rods lightly ported heads SRT headers stock exhaust car has great power flat pulls hard all the way gets a easy 25 mpg on 91 and still has sad 2.62 rear gears and comes out of the hole great for that gear and car weight put in the cam and run it you will be in love..
ACCELERATION SPECIALIST
