t5 behind 5.7 in an abody? #2600344
01/02/19 10:42 AM
01/02/19 10:42 AM
omahell, ne
buconine Offline OP
buconine  Offline OP
omahell, ne
Just picked up a 5.7 out of an 05 jeep and want to do a manual trans that won't require a lot of metal fab. Anyone done a t5? i have one laying around from an old mustang project and see quicktime makes the swap bellhousing. Thanks for your input.
Re: t5 behind 5.7 in an abody? [Re: buconine] #2600362
01/02/19 11:47 AM
01/02/19 11:47 AM
Canada
onig Offline
onig  Offline
Canada
You'll have to mod the trans tunnel brace for the shifter to fit.
69 Dart
Re: t5 behind 5.7 in an abody? [Re: buconine] #2601314
01/04/19 02:15 AM
01/04/19 02:15 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
I don't think a T5 is strong enough for a 5.7L Hemi, unless you are just driving it around town.
They were the perfect gear ratios for the 225 hp truck engine in the Mustangs but 1st id geared a little low and the rest are a little wide.
What are your intentions for this A body?
Re: t5 behind 5.7 in an abody? [Re: buconine] #2601374
01/04/19 10:23 AM
01/04/19 10:23 AM
omahell, ne
buconine Offline OP
buconine  Offline OP
omahell, ne
autox and track days mainly. I'm doing the 8.8 swap in the rear and i thought going t5 would simplify any driveshaft issues. I've been autoxing a fox mustang for years with a t5 without any issues. The car will never dead hook like a drag car.
Re: t5 behind 5.7 in an abody? [Re: buconine] #2601377
01/04/19 10:36 AM
01/04/19 10:36 AM
P
Porter67 Offline
Porter67  Offline
P
I used to destroy new T-5s with BFG Comp TA-s street racing with a 3:73 rear gear, no cats, ect, moved up to the ford motorsport T5 and no more breaky.
If you look I dont think the oem T5 is TQ rated very high.
If I recall correctly it was third or something related to 3rd gear id break, but dont hold me to it.
I also autocrossed this car too with the basic rancho kits out at the time.
Re: t5 behind 5.7 in an abody? [Re: Porter67] #2601434
01/04/19 01:28 PM
01/04/19 01:28 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
stock they are rated to 275FT-LBS-325 depending on year, the S-10 T-5 was good for about 325FT-LBS
3rd is what breaks it's the same deal as the A833's the main shaft spreads away from the Cluster losing teeth engagement.. except the A833 does it at about 200FT-lbs more.
If your dead set on a T-5 https://astroperformance.com/ can build you a 600FT-lbs T-5 for about 3K and http://www.pro-forceperformance.com/ can do 450 FT-lbs for about 2500,
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: t5 behind 5.7 in an abody? [Re: buconine] #2601864
01/05/19 12:11 PM
01/05/19 12:11 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I shredded several T-5s in my mustang that put 300 to the tire and ran 12.30s. It broke 3rd on the cluster normally, but once I quit driving it like I was Ronnie Sox it still broke the input gear on occasion.
68 Barracuda Formula S 340
