Re: Where are the big power turbo 5.7 guys?
[Re: 1mean340]
#2595861
12/23/18 05:31 PM
12/23/18 05:31 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
Mines not done yet... I opened the ring gap which should help on this '12 5.7, but since got all forged internals for an earlier 5.7 and have a 6.1 assembled too.
Theres a member here glhmini I believe is his screen name who has a turbo 5.7 jeep that runs pretty strong.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: 1mean340]
#2596223
12/24/18 12:21 PM
12/24/18 12:21 PM
Posts: 2,697 Renton Wa
topfueldart
Renton Wa
It just bothers me seeing so many people I know making 650+ RWHP with cheap, basically stock bottom end 5.3 turbo builds that still last and take a beating, but you'd be convinced from most Mopar resources that you'd need something like the $2100 MMX drop in forged piston/rod/6.1 crank combo just to start with.
I almost feel like there are a ton of guys in every Mopar group quick to point out how you can't make XXX power with a lot of the factory bottom end parts but you hardly see anyone trying. I mean, I'm sure there is a logical reason for that and it is probably because you don't find 5.7's in junkyards for $500 like you do with GM 5.3's. , but without a solid group of guys pushing the limits it makes me wonder how we know so much about what those limits are?
Nail on the head. There just aren't enough Mopar guys willing to take the chance and put in the work to do it, or re-do it when it breaks for that matter. It takes a bit more money to get in the door with a hemi than it does an LS, and most guys would rather pony up the dough for pistons and rods as "insurance" than give it a shot as is and risk doing irreparable damage. Lots of people get stuck in the mentality of chasing a number horsepower wise, and never even bring the project to fruition. There is a guy on here with a yellow Duster and a 5.7/S475 with im pretty sure stock internals that's been in the low 6's in the 1/8th, and the aforementioned Jeep which has only pistons and has been in the mid 10's as well, so there are a few people doing it on a pretty low buck scale.
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
[Re: Silver70]
#2596365
12/24/18 05:03 PM
12/24/18 05:03 PM
topfueldart
Renton Wa
https://www.hotrod.com/articles/hrdp-1106-turbocharged-hemi-engine/Very old article, using a stone stock pre-eagle 5.7. Also openly discusses the junkyard cost differences, and general internet theory regarding piston strength.
[Re: 1mean340]
#2596406
12/24/18 06:24 PM
12/24/18 06:24 PM
Posts: 1,545 Michigan
Kiddart
the concept of building with spare parts is just that. build it for as little as you can and run it hard. I see it a lot with the ls motors. I am doing my 5.7 in steps. I used a junk yard block and everything inside. I did hone the cylinders put new bearing in it and oil pump. I am in for just under $1000. I have spent more money on the computer and harness and headers. I will know shortly if this pays off. If I break it I will then do the drop in pistons and rods. I just want to drive this car everywhere and not burn $8 a gallon. I am sure I will find its limits really quick, then the sky is the limit, but I will do it with as many factory parts I can. if the new demon can do so can my little 5.7.
plus its nice to buy engine parts on the cheap.
just my two cents
Thank you Kiddart
[Re: Silver70]
#2596644
12/25/18 03:44 AM
12/25/18 03:44 AM
Posts: 112 Michigan
ghinmi
The jeep has the drop in piston and rods.
It does have the drop in pistons and rods now but I did run the stock stuff for a long time. Never had a failure of any kind. I was going to have to take it apart to gap the rings if I wanted to turn it up so I upgraded instead. I drive it too much to worry about it. If it was just a weekend vehicle, I'd gap the rings and be done with it. The stock parts are fine and really not much different than LS stuff. They will take a bunch of power if you have the right game plan and manage cylinder pressure (hint, lots of rpm). And it will not happen on a stock ECU, save the headaches and go with an aftermarket standalone right off the bat.
1975 Jeep Cherokee compound turbo 5.7 Hemi/6 speed AutoX/Drag/Street. 9.97 @ 140 slicks, 10.74 in autox trim
[Re: 1mean340]
#2598407
12/29/18 03:33 PM
12/29/18 03:33 PM
Posts: 361 Canada
onig
Canada
I have an 04 5.7 that I wanted to test the limits of the stock bottom end with a turbo. The engine had a ticking noise when pulled out, but started and ran fine. Taking it apart found the exhaust manifold was cracked. That made me feel good, not the bottom end. Inside the engine was a bent rod that was lightly taping the piston making the ticking noise. So that testing the stock bottom end went to H@?L. Disappointed I was.
69 Dart
[Re: 1mean340]
#2599151
12/31/18 12:33 PM
12/31/18 12:33 PM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
the big issue for the early Hemi(03-08) is the piston , the top ring is too far up and the factory end gap is too tight, open up the gap to about .014 you can go as high as 12lbs with a great tune, and good tune 10 is max, crappy tune and you'll go boom at 8. the later 09+ 5.7 is a better "stock" engine to boost, the top ring was moved down on the piston,
Truth has no agenda, but those with an agenda make their own truth. Some of us are so open minded they only see their View
[Re: MattW]
#2600359
01/02/19 11:45 AM
01/02/19 11:45 AM
Posts: 361 Canada
onig
Canada
You want a stock used replacement piston and rod for free? Thanks, but I am not going to use the stock bottom end.
69 Dart
