mopar jack restoration #2593769
12/18/18 02:55 PM
12/18/18 02:55 PM
louisiana
musclecarman15 Offline OP
louisiana
who does proper mopar jack restoration...correct paint color and hollow tube replating...thx keith
Re: mopar jack restoration [Re: musclecarman15] #2593944
12/18/18 08:29 PM
12/18/18 08:29 PM
SE Wisconsin, USA
RP's R/T's Offline
RP's R/T's  Offline
SE Wisconsin, USA
That is Moparts member 'Floyd'.
High quality and detailed, but I am not sure he is taking on any more projects at this time.
Re: mopar jack restoration [Re: RP's R/T's] #2593958
12/18/18 08:58 PM
12/18/18 08:58 PM
MD
floyd Offline
floyd  Offline
MD
I only did the one vintage Mopar Parts floor Jack.😀
Sounds like you’re looking for bumper jack resto info. I have done some solid mast jacks, but never did a hollow-tube.
Here’s an old post with some info on disassembly:
https://board.moparts.org/ubbthreads/ubbthreads.php/topics/1616691/1.html
And another on paint colors:
https://board.moparts.org/ubbthreads/ubbt...tml#Post1965062
Good luck
Re: mopar jack restoration [Re: floyd] #2594038
12/19/18 12:32 AM
12/19/18 12:32 AM
blewbyu Offline
blewbyu  Offline
I had SF Restoration do mine. They are a sponsor on here and it looks Fantastic. click on link to see His work. up
https://board.moparts.org/ubbthreads/ubbt...eps.html#UNREAD
Re: mopar jack restoration [Re: musclecarman15] #2594203
12/19/18 12:57 PM
12/19/18 12:57 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
They aren't hard to do yourself. Just look for a local electroplating company who does zinc dichromate. I spread the mechanism apart on mine so I could remove it from the shaft. I painted the mechanism and reinstalled it on the replated shaft when I got it back. It turned out great. The hardest part was finding a gray paint that matched the original color.
Re: mopar jack restoration [Re: burdar] #2594213
12/19/18 01:23 PM
12/19/18 01:23 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
[/url
[url=https://postimages.org/]
What he said !! twocents
Re: mopar jack restoration [Re: musclecarman15] #2594223
12/19/18 01:37 PM
12/19/18 01:37 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Can you provide some more info on how you spread the mechanism? Thanks
Re: mopar jack restoration [Re: musclecarman15] #2594228
12/19/18 01:57 PM
12/19/18 01:57 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Floyd posted a link to some suggestions on getting the mechanism off. I did mine 6 years ago so I'd have to look closely at the mechanism again to remember exactly what I did.
I know there are some raised sections on the mast that prevent the mechanism from being removed. I think I just pried on the mechanism with a screw driver where the raised areas made contact. Once the mechanism was pushed over the raised sections, I was able to tap it off with a rubber hammer.
Now that I think about it, I might have reinstalled the mechanism onto the replated mast BEFORE repainting it. I might have masked off one end of the shaft, slid the mechanism to that side, repainted it and then removed the masking. Don't remember exactly any more.
Re: mopar jack restoration [Re: musclecarman15] #2594353
12/19/18 06:11 PM
12/19/18 06:11 PM
8
86 Shelby GLHS
86 Shelby GLHS
My mechanism for a '70 Challenger was gray, so I found a gray primer that matched very closely and then sprayed a clear coat over it.
Re: mopar jack restoration [Re: musclecarman15] #2594792
12/20/18 08:27 PM
12/20/18 08:27 PM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
I used some Rustoleum Gray Industrial paint that came in spray cans it was a perfect match to the mint jack I have
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: mopar jack restoration [Re: musclecarman15] #2594798
12/20/18 08:43 PM
12/20/18 08:43 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
If I'm not mistaken it is Dove gray. work
Re: mopar jack restoration [Re: 5carguy] #2595172
12/21/18 07:32 PM
12/21/18 07:32 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
correct
