05 gen 3 with 09 heads
#2593323
12/17/18 07:35 PM
12/17/18 07:35 PM
Posts: 1,546 Michigan
Kiddart
Before I get to far in front of myself. is there anything I need to watch out for when I put these heads on my stock block, rods and pistons. I have read and been told this is a direct swap, rockers and push rods as well.
I just want to make sure. I have had my share of setbacks this last week with this motor and want to make a step forward not two backwards.
I have all new head bolts and factory head gaskets
Thank you Kiddart
Thank you Kiddart
Re: 05 gen 3 with 09 heads
[Re: Kiddart]
#2593351
12/17/18 08:23 PM
12/17/18 08:23 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Is this for a stock aplication or swap? Intake manifold is different. Same bolt pattern but ports wont line up.
[Re: Kiddart]
#2593454
12/17/18 11:20 PM
12/17/18 11:20 PM
Kiddart
Sorry fellas this is for a swap. I will be using my Cascar intake with my Fast efi system and the Hemi 6 ignition box. I know I will have to watch the tune and timing but more worried about oil passages and water jackets. I am 99% sure its a direct swap. and yes I have read that the combustion is now going to be 11 to 1. I am ok with that and plan to run premium gas anyways.
Thank you Kiddart
[Re: Kiddart]
#2593529
12/18/18 12:55 AM
12/18/18 12:55 AM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
Cam base circle is different on the earlier and eagle 5.7s. You'll need different length pushrods. I'm sure you can find the right length searching on google.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: Kiddart]
#2593694
12/18/18 12:13 PM
12/18/18 12:13 PM
Kiddart
so on the 09 heads the rocker pedestals are higher? I am keeping the original cam and lifters. so now I need push rods as well, what pushrods? any part number?. boy the price just keeps going up.
Thank you Kiddart
[Re: Kiddart]
#2593711
12/18/18 12:46 PM
12/18/18 12:46 PM
Kiddart
quick search from 03 to 08 all pushrods are the same. Intake 7.850 Exhaust 6.600 09 and newer only changes with VVT from what I see on a quick read of a search A2Speed is saying correct length to remove any and all lifter clatter is 6.80 int and 8.1 exhaust. I will measure mine and see what I have. I just might buy a set of pushrods. any and all comments are welcome.
Thank you Kiddart
[Re: Kiddart]
#2593827
12/18/18 04:01 PM
12/18/18 04:01 PM
HotRodDave
Kalispell Mt.
You can use stock eagle pushrods.
[Re: Kiddart]
#2593862
12/18/18 04:56 PM
12/18/18 04:56 PM
Kiddart
Hotroddave,
I will order a set of 09 and up push rods. and I have the valve covers already because I switched to the new coil pack for my MSD box.
Thank you Kiddart
[Re: Kiddart]
#2593982
12/18/18 10:13 PM
12/18/18 10:13 PM
HotRodDave
Kalispell Mt.
The one we did was fine. I didn't know about the base circle difference but it seems there is enough play in the lifter to accommodate it...
[Re: Kiddart]
#2594833
12/20/18 10:12 PM
12/20/18 10:12 PM
Kiddart
So no new pushrods?? I can use my 04 pushrods and my 04 camshaft.
Thank you Kiddart
[Re: Kiddart]
#2595015
12/21/18 12:38 PM
12/21/18 12:38 PM
Kiddart
Sliver70
I am using stock cam. for now.
Thank you Kiddart
[Re: Kiddart]
#2596360
12/24/18 04:54 PM
12/24/18 04:54 PM
HotRodDave
Kalispell Mt.
12 to 1 seems to be of no real concern with pump premium, these new hemis have a very high tolerance for compression with dual spark plugs requiring less ign lead, plastic intakes keeping the air very cool, very efficent chambers, very good oil control, EFI... lots of people are running this combo with stock head gaskets and premium fuel with no issues.
On a side note, when I CCd everything a while back I was barely able to come up with 11.5 with this combo once I calculated in the pistons below deck and all.
