Regulator for carb with EFI in-tank pump...
#2593373
12/17/18 09:18 PM
12/17/18 09:18 PM
Posts: 3,031 Erda, UT
67Charger
Erda, UT
My Magnum 5.9 doesn't have fuel pump boss, and I'm tired of the noise from the Holley Red back by the tank. I'm about to go to one of the Spectra EFI tanks but I need to regulate it down for a carb.
Aeromotive makes 3 different regulators with this specific application in mind, but really, whats preventing me from using a plain old bypass regulator that I have lying around? Specifically my old Mallory 29387?
11.33 @ 118.46 on motor 10.75 @ 125.35 w/ a little spray Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
Re: Regulator for carb with EFI in-tank pump...
[Re: 67Charger]
#2593383
12/17/18 09:43 PM
12/17/18 09:43 PM
Andrewh
https://www.summitracing.com/parts/maa-2...T0aAuPDEALw_wcBcheck out the comments. you can, as long as it is plubmed right. the guy in comments that didn't is doing the same basic setup you are and the smaller return line is messing him up.
[Re: 67Charger]
#2593448
12/17/18 11:14 PM
12/17/18 11:14 PM
Posts: 2,842 Pattison Texas
CSK
Pattison Texas
This is the one I have CLICK HERE
[Re: 67Charger]
#2593450
12/17/18 11:16 PM
12/17/18 11:16 PM
CSK
Pattison Texas
The one you have should work
[Re: CSK]
#2593620
12/18/18 06:13 AM
12/18/18 06:13 AM
Posts: 139 Pennsylvania
polaris400cc
Pennsylvania
I specifically used that regulator on my 95 5.9 Magnum long block with carb. Used 3/8 for return line on my ramcharger and ended up having to run a 1/2 return because of the distance Back to the tank. Was getting some erratic psi numbers at times. Other than that hiccup its been flawless.
I used a 91 OEM plastic tank with stock tbi pump. Drilled a hole on top of tank and used a bulkhead fitting for the return. So I could use the original supply fitting off of the sending unit.
[Re: AndyF]
#2593916
12/18/18 07:33 PM
12/18/18 07:33 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
You can mount the regulator back by the gas tank as long as the fuel line is kept cool. The fuel line will be dead headed so it will be more susceptible to heat. But it can be made to work, a lot of new cars are done that way. that's pretty much how our vehicles were from the factory. No regulator per se, but when the inlet needles were closed the fuel was dead heading.
[Re: 67Charger]
#2593917
12/18/18 07:39 PM
12/18/18 07:39 PM
CSK
Pattison Texas
I am in Southeast Tx, it gets hot here, I run 3/8 supply & 3/8 return, all line insulated to keep from heating up the fuel in the tank, regulator is near the carb it works very well, I drive my car & it has A/C.
[Re: 67Charger]
#2594655
12/20/18 01:08 PM
12/20/18 01:08 PM
67Charger
Erda, UT
What I had in mind was putting hthe regulator right next to the tank, and if there IS a vapor issue, either use the vapor return filter to bleed a little fuel back to the tank or use a second regulator at the carb set 1 psi below the back regulator and use the vapor return line as a return line for the minimal return fuel. This way it does not handle ALL the bypass fuel, just the 1 psi difference.
I would think a vapor return filter would be adequate...
