Lighting amp draw? #2592406
12/15/18 04:10 PM
12/15/18 04:10 PM
Indianapolis In. usa
Quickrunner Offline OP
Using modern led bulbs on tail lights, and marker lights if available, and upgraded modern replacement headlights. What kind of amp draw can be expected just from lighting? And who makes nice upgraded bulbs and such? Ground up build 71 demon.
05 Ram 1500 Daytona package
71 Demon Gen3 hemi drag radial project
Missin' my 9 second 70 runner!
Re: Lighting amp draw? [Re: Quickrunner] #2592412
12/15/18 04:28 PM
12/15/18 04:28 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
You need to define upgraded modern replacement headlights
Halogen headlamps would qualify on a 71 Demon.
LED headlights for a 71 Demon show about 1.1A per bulb.
Halogen headlamps for a 71 Demon draw ~5/2.75A (high/low beam), incandescent similar.
LED bulbs generally draw a few milliamps, but that is also dependent on how bright they are. If you had a specific bulb(s) in mind post a link.
IOW, not enough info to answer your question other then to say less that original.
Don't be the exception.
Re: Lighting amp draw? [Re: Supercuda] #2592414
12/15/18 04:34 PM
12/15/18 04:34 PM
Specific headlights and bulbs have not been decided on yet. Just looking for a number to plug into the rest of my list of amp usage on the car. Designing a drive system for motorplate custom build and looking at how many amps my alt needs to have the ability to pump out. Say worst case scenario what would the stock lighting pull amp wise minus the dash lighting?
Re: Lighting amp draw? [Re: Quickrunner] #2592424
12/15/18 05:20 PM
12/15/18 05:20 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Stock headlights in '71 were either used 6012 or 6014 lamps.
6012s are nominall 50/40 Watts
6014s are nominally 60/50 Watts.
H6024 are generally 65/35 Watts but the GE H6024NH are 65/55 Watts
H4/HB2 type bulbs (used in seperate lamp housing) are nominally 60/55 Watts
http://www.candlepowerforums.com/vb/showthread.php?392498-Interesting-headlight-bulb-test-results
My understanding is the nominal power draws are at 12.8 Volts (US standard)
At high voltage, lets say system is regulated to 14.2 Volts, bulb power draw will be higher than the nominals
If you want to ballpark worst case:
Say 75 Watts at 14 Volts = 5.35 amps for each lamp, or roughly 11 amps for the pair.
Circuit breaker in the A bodies was 15 amps.
