cascar intake question
#2591033
12/12/18 08:52 PM
12/12/18 08:52 PM
Posts: 1,548 Michigan
Kiddart
I bought a Cascar intake from Prefix(very Nice piece) I have one question. on some of the other intakes they offer a filler neck cover, some of these have a spot to put a breather. since I am not running the factory PCM will I need to add a breather to the oil fill cap they provided?
Thank you Kiddart
Re: cascar intake question
[Re: Kiddart]
#2591908
12/14/18 04:05 PM
12/14/18 04:05 PM
Kiddart
for me the map sensor is in my throttle body. I am going to see what happens first before I drill a hole in the cap. the cap with breather is like $240. outrageous
Thank you Kiddart
[Re: Kiddart]
#2607740
01/16/19 09:22 PM
01/16/19 09:22 PM
Kiddart
Ok has anyone any other ideas? Prefix supplied me with a cover plate, no gasket. it could become a pain in the butt adding oil if needed. I have been searching ways to adapt a stock filler to the intake but no such luck. any help and suggestions welcome. keep in mind this intake does not have the threaded boss area that the Ritter and the OC intake has.
Thank you Kiddart
[Re: Kiddart]
#2608050
01/17/19 01:41 PM
01/17/19 01:41 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
John, sounds like you should start making adapters
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: Kiddart]
#2609830
01/21/19 12:57 PM
01/21/19 12:57 PM
Kiddart
John, I never thought of this. I am sorry for my stupidity. that's is a fantastic idea!!!
thanks a million I am ordering one right now.
Thank you Kiddart
[Re: Kiddart]
#2617242
02/05/19 11:40 AM
02/05/19 11:40 AM
Kiddart
ouch is right. I have made a solution and will be getting a few 3D printed to see how they work.
thanks for all the help.
by the way Mancini's sells a breather cap with a threaded nut for $5 bucks. they are sitting on the counter. tig the nut to the plate do some creative hole grinding and you have a solution. or get the one that was mentioned above. either will work, when I get mine back I will snap some pictures and post.
Thank you Kiddart
[Re: Kiddart]
#2619727
02/11/19 12:08 PM
02/11/19 12:08 PM
Kiddart
just the first printout. this material is only good up to 190 degrees. looking for something different. I will check the fit this week when I have time
Thank you Kiddart
[Re: Kiddart]
#2619738
02/11/19 12:33 PM
02/11/19 12:33 PM
Kiddart
I have the original one that is alum. I am just seeing what can be done on 3d printer.
Thank you Kiddart
[Re: Kiddart]
#2620700
02/13/19 10:28 AM
02/13/19 10:28 AM
Posts: 1,462 Mrytle Beach SC
johnscudashop
Mrytle Beach SC
just the first printout. this material is only good up to 190 degrees. looking for something different. I will check the fit this week when I have time Very nice.. Thats what I had in mind. What was the part # on the Aluminum Cap and neck assembly from Mancini ?
[Re: Kiddart]
#2620752
02/13/19 01:28 PM
02/13/19 01:28 PM
Kiddart
I don't recall, they are in a box on the counter, next time I am in there I will get the number.
Thank you Kiddart
