Re: 2nd Gen Hemi, what cam size?
[Re: 590 Challenger]
#2592550
12/15/18 10:25 PM
12/15/18 10:25 PM
Posts: 5,103 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
Once we cut the roller lifter apart and push it enough out of the way to pull the Cam shaft out and then push the lifter into the cam location to get it out without any damage, I will measure the cam journals to see what they measure on the cam shaft. Motor ran good with a main stud laying in the oil pan 870s and the roller bearing gone away on one lobe. Cam is still good but this Indy block has been a pain over the years. Might take a few weeks.
1971 HEMI E BODY REGISTRY
[Re: hemicar1971]
#2592573
12/15/18 11:25 PM
12/15/18 11:25 PM
Posts: 493 Parts unknown
590 Challenger
Parts unknown
Once we cut the roller lifter apart and push it enough out of the way to pull the Cam shaft out and then push the lifter into the cam location to get it out without any damage, I will measure the cam journals to see what they measure on the cam shaft. Motor ran good with a main stud laying in the oil pan 870s and the roller bearing gone away on one lobe. Cam is still good but this Indy block has been a pain over the years. Might take a few weeks. Thanks, sounds like a nightmare. I just switched from the indy block, I had a no problems with it, but being it was one of the first water blocks with no webbing, I was really worried about breaking it. Good luck
#2592649
12/16/18 03:41 AM
12/16/18 03:41 AM
Posts: 3,504 DFW
mr_340
DFW
http://www.compcams.com/Pages/410/chrysler-technical-info.aspxCamshaft Journal Diameter Many of the newer racing engines utilize a larger than standard cam bearing journal diameter. The advantages of the larger diameter are less flex and a larger base circle to smooth out the lobe design, making this a very desirable addition to any extreme racing engine. It is very common to use a 2.125” Ford babbit bearing in the Hemi engine. Some of the latest oval track blocks feature a roller bearing and require a 1.968” journal diameter. Make sure to specify journal size when ordering your cam. If no special size is requested, the standard journal will be chosen.
Floyd Lippencott IV
#2592947
12/16/18 09:41 PM
12/16/18 09:41 PM
hemicar1971
Chicago Blackhawks
I measured the cam shaft were the bearings would be and it came to 2.167, 2.169, 2.1685, 2.170, 2.1675. Tough one with the cam roller bear still in it but here is what I got but it could be a little off, 2.2484-----2.150. Hope this helps block will go to the machine shop in a couple of day to be honed.
#2592952
12/16/18 09:51 PM
12/16/18 09:51 PM
hemicar1971
Chicago Blackhawks
55mm equals 2.16
60mm equals 2.36
62.738 equal 2.47
I would imagine it would depend on what bearing you are running to make up the distance between block and cam. You might need to call someone like Tim Banning or Todd on this board Saquash and ask them they have more experience than I have with building different hemi motors.
