Re: Driveshaft transmission yoke engagement question
[Re: 440mopar]
#2591854
12/14/18 02:32 PM
12/14/18 02:32 PM
RapidRobert
I like 5/8-3/4 back from butted, with the suspension loaded (not hanging free).
[Re: RapidRobert]
#2591916
12/14/18 04:23 PM
12/14/18 04:23 PM
Posts: 25,731 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The "shove it in and pull it out X amount" won't work with the rear seal that has a dust boot.
Factory diagram below shows the preferred slip yoke position.
[Re: 440mopar]
#2591921
12/14/18 04:35 PM
12/14/18 04:35 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
So, it looks like you should be able to measure from the axle yoke flat to the end of the tail housing and subtract
3.74" for the 727 3.58" for the 904
and have the drive shaft u-joint center to center dimension.
