#2591254 - 12/13/18 09:27 AM AAA roadside replacement battery?
magnum440d100 Offline
Loc: woodcrest, CA
My DD Honda needs a new battery. Cheapest I’ve found is through my AAA roadside for $110. It says they have a 6 year warranty with a 3 year free replacement.
Anyone here run a AAA battery in their vehicles? Any issues?
TIA!
#2591271 - 12/13/18 10:01 AM Re: AAA roadside replacement battery? [Re: magnum440d100]
moparx Online   content
Dreaming of implants
Loc: north of coder
from what i can tell, there are only a hand full of battery makers, just different stickers and case colors.
beer
#2591274 - 12/13/18 10:08 AM Re: AAA roadside replacement battery? [Re: magnum440d100]
BSharp Offline
Loc: Virginia
I had AAA replace a battery and it lasted several years. Don't remember exactly, but it was acceptable.
#2591309 - 12/13/18 11:09 AM Re: AAA roadside replacement battery? [Re: magnum440d100]
hemi-itis Offline
Loc: Great Neck,LI,new york
TIA!
nt
I'd go with it and kill it every 2 years for the FREE replacemet! whistling
HEMI-ITIS has no cure. My condition is fully BLOWN!!!
New best 60ft,, 1.42,1/8, 6.0 @117,, 9.38 @146.75 with 6 lbs boost @3700 lbs
#2591312 - 12/13/18 11:15 AM Re: AAA roadside replacement battery? [Re: magnum440d100]
a12rag Offline
Loc: Calgary, Alberta Canada
So I thought I had battery issue on my Journey . . . called in and was told they would send out the service truck . . . . guy gets here, looks at my Journey, and shakes his head - then tells me : "Because of the location of the battery, under the left front splash shield - remove front tire, that they DO NOT DO these !!!" . . . . "WHAT???" . . . if that is the case, then WHY did the person on the phone, that sent the guy out, NOT KNOW THAT ?!?!?! . . . . turns out the battery was ok, not sure why it was drawn down, but put on charger and then checked with load tester - all good !!! . . .
Have had friends use this service over the years, and has been good for them. Heck, someone COMES to you, with a battery, replaces your dead one, AND takes old one away . . . CHEAPER than what you can buy a battery for ?!?!? . . . I say go for it !!!
#2591358 - 12/13/18 01:14 PM Re: AAA roadside replacement battery? [Re: a12rag]
Loc: woodcrest, CA
Yeah I was reading that they may charge a labor fee if they have to do that kind of work.
Anyway, I ended up paying $130 after tip, which is still way under what the brick and mortar store....
#2591532 - 12/13/18 07:30 PM Re: AAA roadside replacement battery? [Re: magnum440d100]
TJP Offline
Loc: Omaha Ne
Had a customers AAA battery go dead while the car was here and the engine was out. (We were doing some electrical testing)
The AAA guy comes out and the battery is sitting in front of the car in the shop. I explained to him we charged it, load tested it and it was toast.
He's looking around and says I can't replace the battery unless its in the car, HUH ??? He repeats himself,
OK, I pick the battery up, put it in the car and look at him glaringly.
He does a load test, says the battery is bad ( REALLY ??) and replaces it. 45 minutes of BS for what could have been done in 5
My experience with AAA beer
www.tandmautomotive-omaha.com
#2591540 - 12/13/18 07:46 PM Re: AAA roadside replacement battery? [Re: magnum440d100]
Dcuda69 Offline
Loc: WI
How much at the brick and mortar? Do you mean buying the battery and installing yourself or going to a shop and having it done.Just curious. I bought a big batt for the wife's Fusion at the local Farm and Fleet for $110....15 min to install.I have AAA but didn't even think to call them when hers crapped in the garage.
#2591545 - 12/13/18 07:55 PM Re: AAA roadside replacement battery? [Re: Dcuda69]
Loc: woodcrest, CA
Brick and mortar as in if I were to buy it and install it myself. Only options it shows is $155 or $185....
#2591605 - 12/13/18 10:08 PM Re: AAA roadside replacement battery? [Re: magnum440d100]
Dcuda69 Offline
Loc: WI
Gotcha....wow! I got a 600CCA for that $110 after core return.
Edit: just looked and it has gone up $10..so $120
https://www.farmandfleet.com/products/67...ve-battery.html
Edited by Dcuda69 (12/13/18 10:13 PM)
#2591631 - 12/13/18 11:10 PM Re: AAA roadside replacement battery? [Re: Dcuda69]
a12rag Offline
Yup, just buying a battery from brick & mortar store is MORE than having AAA come and R&R and take away the old battery !!
#2591645 - 12/13/18 11:43 PM Re: AAA roadside replacement battery? [Re: a12rag]
rhad Offline
Loc: garnett kansas
51R is what my mower uses,i bought a interstate tyhis year for $99.95
my ladder of success is missing some rungs
#2591661 - 12/14/18 01:22 AM Re: AAA roadside replacement battery? [Re: Dcuda69]
Loc: woodcrest, CA
Dang! Just checked a 51r there and it’s $109... I’m not even sure we have a farm and fleet here in California.....
My tenant works at a valvoline and told me AFTER I bought my battery that she could have gotten me an interstate for 50% off....
Just as well... I’m doing a fair bit of travel for work anymore, so a AAA battery that should be covered continent wide, seems better than trying to find an interstate dealer when you’re 3,000 miles from home.
Such is life I guess....
#2591668 - 12/14/18 01:38 AM Re: AAA roadside replacement battery? [Re: magnum440d100]
Guitar Jones Offline
Loc: in a cattle trailer down by th...
The take away I got is that the Honda uses the same battery as a lawn mower. laugh2
I never learned to count my blessings, I choose instead to live inside my disasters.
The Scamp is sold, now just two old trucks and one new one.
'74 W200 Crew Cab 360, NP435, D44, D60 and NP205 divorced transfer case. Magnum 5.2 MPI and NV4500 coming soon.
2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi!
#2591674 - 12/14/18 02:06 AM Re: AAA roadside replacement battery? [Re: Guitar Jones]
Loc: woodcrest, CA
I suppose it does! Haha
Would have been better if I could have taken the battery from my Suzuki ls650 and use it. Dang thing is only a few inches by a few inches and was over $100 itself!!
#2591757 - 12/14/18 09:34 AM Re: AAA roadside replacement battery? [Re: magnum440d100]
Loc: north of coder
just last week i bought an 850ca decka for $130 at the local feed and battery store.
and to think, i use to moan and complain when a new battery cost $19.95 eek just outrageous !
beer
#2591778 - 12/14/18 10:05 AM Re: AAA roadside replacement battery? [Re: moparx]
pittsburghracer Offline
"Little"John
Loc: PA.
beer
And I'm betting the one for 19.95 lasted longer too. Lots of JUNK batteries out there now.
1970 Duster
Edelbrock headed 408
6.143@110.85 mph
9.73@135.05 mph shifting at 6700 RPM
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Untitled by John Cadamore, on Flickr
#2591787 - 12/14/18 10:15 AM Re: AAA roadside replacement battery? [Re: pittsburghracer]
Loc: north of coder
beer
right on the money ! back in the day, i've had battery's last 10-12yrs, including the cheapo's.
i always buy the biggest ca i can find, but it seems lately, all you can get in "big" ca is around 600. that is, unless you go to a specialty battery store.
and today's warrentees are a joke as well.
beer
#2591906 - 12/14/18 01:04 PM Re: AAA roadside replacement battery? [Re: magnum440d100]
Sinitro Offline
Loc: So Cal
There are only a few lead-acid battery suppliers...
Mainly due to the environmental issues especially with lead...
The AAA batteries are sourced from Interstate...
Tried to find out where their factories are, but found out most come from Mexico that has looser environmental standards...
Just my $0.02... wink
#2591937 - 12/14/18 02:08 PM Re: AAA roadside replacement battery? [Re: Sinitro]
Loc: north of coder
johnson controls is another manufacturer.
beer
25,688 Registered Members
196,640 Topics
Correct front wheel cylinders for 10" drum brake A-Body?
by vinnyd76
01/16/19 11:22 AM
Holley Debuts G3 Hemi Valve Covers From Sniper EFI
by Rustymuscle
01/16/19 11:20 AM
Sweptline parts trucks 2 1/4 ) Lincoln , Neb $2500
by bigdad
01/16/19 11:14 AM
1964 Plymouth 4 door , Lincoln Neb area --$800
by bigdad
01/16/19 11:09 AM
