BB Rod and Main Bearings
#2590820
12/12/18 01:29 PM
12/12/18 01:29 PM
Posts: 1,505 TN
SCATPACK 1
TN
Starting on a new build. Whose main and rod bearings do you use and why? This will be a 572 with 2.20 rods and standard 440 main size. I have ordered bearings in the past that varied between pairs and also one set would have more thrust clearance than the next set would. Just looking for some consistency and thought I would pick your brains on this. thanks in advance Jerry
Old Geezer Racing
Re: BB Rod and Main Bearings
[Re: SCATPACK 1]
#2590878
12/12/18 03:37 PM
12/12/18 03:37 PM
Posts: 43,124 Bend,OR USA
Cab_Burge
I like and use the Federal Mogul H.D. full narrow groove truck main bearing sets #4095 and the Federal Mogul BB Chevy rod bearings that are narrowed and chamfered # 2320P or the Clevite # CB743N or the King bearing # CR806XPND depending on what size the crankshaft journals are(stock or over or under that size) and how much clearance I measure with all of the bearings I shoot for more clearances than some others on here, I like to use the .0010 + for each one inch of journal size, IE minimum of .0022 or more for the BB Chevy rod journals and a minimum of .0028 on the BB Mopar main bearing clearances IHTHs
[Re: SCATPACK 1]
#2590949
12/12/18 05:20 PM
12/12/18 05:20 PM
Posts: 4,206 New York
polyspheric
New York
.001" per inch of journal: 100 years old.
Boffin Emeritus
[Re: SCATPACK 1]
#2591608
12/14/18 01:21 AM
12/14/18 01:21 AM
Posts: 3,097 back in Georgia
dthemi
back in Georgia
Well, for me I've become a fan of King in a drag race motor like most of us build. Clevite is a great bearing as are most that's out there these days.
I like King for a couple reasons in a race motor. First the bearing is tapered, so as the crank flexes, it's less likely grab near the radius. Second, they're really tough, and the normal crap flying around in the oil gets embedded pretty easily. They're also very forgiving in the ole no oil on shut down, start up ect. They also give a bit more clearance, if you're under the max housing bore size. Also seem to be more round after the parting relief.
As for clearance, .0035 on rods and mains for me, and no less than .003. I'd rather have .005 than .002anything, but that's just me.
[Re: SCATPACK 1]
#2591735
12/14/18 11:47 AM
12/14/18 11:47 AM
Posts: 8,031 Mt Morris Michigan
mopar dave
Mt Morris Michigan
I used the King rod and cam bearings in my LD 511 for the first time. Used Molnar crank and rods with 2.200 journal. King CR808HPN rod, Clevite H half groove bearings on the mains. Bought 2 sets to get full groove oiling on the main. Clearances came out real nice first try at .0028 on rods and .0033 on mains. Still running with 65-70# hot oil pressure cruising and 30# idle hot using Amsoil 15/50 Dominator. So far so good. Correction: I used the Clevite ms876p full groove main bearing.
[Re: dthemi]
#2591751
12/14/18 12:28 PM
12/14/18 12:28 PM
BradH
Hey fast mark, did you use the HP kings, or their other lines? I'd like to know if you guys are using King's tri-metal (HP?) or standard bi-metal (aluminum?) bearings. The recommended applications for bi-metal bearings vary significantly, depending on which company's guidance I've read. Looks like tri-metals are going to be a thing of the past for a couple of reasons that I've heard. No OEMs use them any longer, and they're prohibited by some countries because of having lead in the tri-metal layers.
