Lower cylinder damage,ok to run? #2590674
12/12/18 01:14 AM
12/12/18 01:14 AM
Pittsburgh,PA
RTSrunner Offline OP
Pittsburgh,PA
Would a block with some minor cylinder damage from a broken rod be ok to run? It is on the bottom of two cylinders,inner edge.It looks like it could be blended ok,like clearancing for a stroker crank. Im pretty sure it will be fine but wondering if anyone has done this on a G3 since the broken rods are somewhat common on the early models.
Thanks,RT
Re: Lower cylinder damage,ok to run? [Re: RTSrunner] #2590680
12/12/18 01:29 AM
12/12/18 01:29 AM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
IMO if the rings don't hit it your good to go.
Matt
Re: Lower cylinder damage,ok to run? [Re: RTSrunner] #2590686
12/12/18 02:00 AM
12/12/18 02:00 AM
Pittsburgh,PA
Pittsburgh,PA
Thanks,way out of the ring sweep area
Re: Lower cylinder damage,ok to run? [Re: RTSrunner] #2590717
12/12/18 04:04 AM
12/12/18 04:04 AM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
The 5.7 in my magnum got beat up down low on the cylinder from a broken rod... I smoothed it out with a die grinder and engine runs perfect now.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
