Help me identify these '71 B-body screws & bolts - SOLVED!
#2590643
12/12/18 12:20 AM
12/12/18 12:20 AM
Posts: 1,074 So Cal, USA
Fab64
So Cal, USA
Hi all, When I pulled my car apart in June 2016, I wasn't as careful as I should have been. I'm guessing this stuff goes near where the steering column meets the dash as it was all in a baggie with the bolts and washers used to hold the collapsible part of the steering column to the under-dash bracket. Unfortunately, I don't see anywhere they should go, and they don't look familiar to me. The philips head screws look like they should hold on a plastic steering column trim piece, but I don't think there is one on this car(?). Any help would be much appreciated! Roger
Re: Help me identify these '71 B-body screws & bolts?
[Re: Fab64]
#2590644
12/12/18 12:23 AM
12/12/18 12:23 AM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
small hex screws ( 1/4" hex head )... side of the windshield vents on speaker grill panel ?
3 phillips ones... speaker area on same panel?
large hex bolts... probably 7/16" ? dash frame "legs" at kick panel area ?
[Re: Fab64]
#2590755
12/12/18 10:28 AM
12/12/18 10:28 AM
NachoRT74
Valencia, España
I never label the screws and bolts on my car either but thats because I have dissasembled my car so many times that just looking at them usually find out the location in a few seconds
