Big block oil pump/distributor drives #2590483
12/11/18 06:01 PM
12/11/18 06:01 PM
A Red State
SNK-EYZ Offline OP
SNK-EYZ  Offline OP
A Red State
Building a street 451 low deck engine.
What are the pros & cans of the different oil pup drives out there?
Is the Mopar Performance one the best option? (about $100)
Are the Mellings and Sealed Power ones acceptable? (about $50)
They all seem to have hardened shafts.
The Mopar one has a pinned on gear, is that preferable?
Will be running a Flat Tappeet Solid Lifter Cam.
Opinions?
Re: Big block oil pump/distributor drives [Re: SNK-EYZ] #2590500
12/11/18 06:36 PM
12/11/18 06:36 PM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
Im thinking I used a Mellings the last time but cant be sure it wasn't mopar.
Have a great day
Iowan
"obsolete is neat"
Re: Big block oil pump/distributor drives [Re: SNK-EYZ] #2590525
12/11/18 07:17 PM
12/11/18 07:17 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I have only used....re-used OEM stock, and MP.
The pin seems like a nice safety idea but after pressing a gear off and on and seeing how crazy tight the press fit was, I'm not sure it's really needed.
I know the pin has been accepted for decades, though, and (when I was able to check back around 2013) I was able to verify the MP one was (at that time) made in Mt. Clemens Michigan, USA. So if that means anything...it does have that going for it, or at least it used to.
Rich H.
Esse Quam Videri
Re: Big block oil pump/distributor drives [Re: SNK-EYZ] #2590543
12/11/18 08:04 PM
12/11/18 08:04 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Any pump drive shaft that has a sharp cut where the round shaft transitions to the hex (see arrow pic below) is likely to snap under a heavy load, choose one that has a gradual transition.
Re: Big block oil pump/distributor drives [Re: SNK-EYZ] #2590574
12/11/18 09:19 PM
12/11/18 09:19 PM
crabman173
crabman173
That is correct engineering-wise but a stock unit will run forever with a FT solid no matter what
In 40 years of the big block Mopar business I have never seen a unit with gear spun on the shaft
That $100 would be better spent elsewhere--IMO
Re: Big block oil pump/distributor drives [Re: ] #2590646
12/12/18 12:26 AM
12/12/18 12:26 AM
Just me if it is not made overseas I would be OK with it. A person could pin the gear themselves (if need be).
