Combination of Brake Parts
#2590074
12/10/18 09:36 PM
12/10/18 09:36 PM
Posts: 10,498 Chicago, Illinois
Devil
Chicago, Illinois
Ok, so I've done a lot of thinking about the brakes on my 1971 Challenger. It currently has stock 10.95" Disk Brakes on it. For what I'm going to do I am upgrading. Reading through some of the old Chrysler Manuals and odds and ends, I've come up with a hodgepodge of brake parts I think will work pretty well. 73-76 A-body Disk Brake Spindles 78 Dodge Monaco (B-body) Cop Car 11.75 pin style caliper mounts 78 HD Disk Brake Rotors 71 Disk Brake Calipers With this I think I should get the benefits of the pin style brakes, but with the larger 11.75" rotors, for not a lot of money. What do you think?
Re: Combination of Brake Parts
[Re: Devil]
#2591306
12/13/18 02:07 PM
12/13/18 02:07 PM
Posts: 801 central CT
cudazappa
central CT
since you're just updating the stock brake system, it can get a wee bit easier if your ball joints are in good shape.
Take your new pin type caliper adapters, and the late B-rotor.
Don't swap spindles, buy the bearing spacer from dr. diff. Now you don't need to pop the upper ball joint and the swap can be done in the time it takes to do a brake job. The only caveat is that the 71 dust shield won't work with the late B brakes. (this would be true even if you swapped spindles.
This is what I did on my 71 challenger and put hundreds of trouble free miles and several dozen autocross laps with no issue.
1971 Challenger
[Re: cudazappa]
#2591313
12/13/18 02:16 PM
12/13/18 02:16 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
I recently completed my 11.75 swap (keeping the pin calipers, and replacing the caliper brackets as needed). I also swapped to the A-body spindles with the larger bearings... in retrospect, I should have just purchased the Dr Diff sleeves... and saved $$$ and time.
Car is not yet driving pending new engine in the works.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: Devil]
#2593928
12/18/18 07:57 PM
12/18/18 07:57 PM
Mopar Mitch
As for the reliability and durability of the smaller bearings, I wouldn't be concerned as I've raced very hard for 30+ years of actual competition pylon autocrossing (SCCA, etc), as well as recent years of very hard hi-speed road course events (HSAX/HPDE). When I've just now taken the old small bearings out, they still looked excellent and didn't have any problems.
The larger bearings are perhaps better for extended durability, but I've had no problems with the smaller bearings from very hard racing (AX/HSAX/HPDE)/driving.
Mopar Mitch
[Re: Devil]
#2596886
12/25/18 07:30 PM
12/25/18 07:30 PM
Posts: 1,401 northeast ohio
hulmule
northeast ohio
My questions My son's cuda had drum brakes on front. Switching over to disc. I found a set of spindles but don't what they came off. They have the 11" rotors on them now. Have a pair of pin style brackets, but with only one slider style bracket. I see Dr. Diff sell brackets, so i can sell the pair of pins and one slider bracket and buy a new pair of slider brackets. Am i thinking correctly with buying slider brackets and calipers for easier installation. I also see he sells drilled /slotted rotors unless we can buy they cheaper elsewhere?? What can i do with the old drums, spindles etc??
1969 Dodge Coronet R/T Convertible 1979 LiL Red x2 2012 Yellow Jacket 2006 mega cab 1977 Trailduster 1979 Trailduster
[Re: crash520]
#2601928
01/05/19 03:07 PM
01/05/19 03:07 PM
Posts: 30,989 Oregon
AndyF
Anyone know of a set of pin type brackets around at a price that’s reasonably fair?? Pin type brackets are scrap around here so basically free. I threw about 50 lbs of them away recently when cleaning out my shop.
[Re: AndyF]
#2602001
01/05/19 06:30 PM
01/05/19 06:30 PM
Posts: 247 Brisbane Australia
crash520
Brisbane Australia
Anyone know of a set of pin type brackets around at a price that’s reasonably fair?? Pin type brackets are scrap around here so basically free. I threw about 50 lbs of them away recently when cleaning out my shop. For the 11.75” rotors??!!
[Re: Devil]
#2606255
01/14/19 01:13 AM
01/14/19 01:13 AM
hulmule
northeast ohio
I have a set , whats the difference between those and slide ?? changing over a E body.
