Which electric water pump ? #2589743
12/10/18 09:54 AM
12/10/18 09:54 AM
Brisbane Australia
crash520 Offline OP
crash520  Offline OP
Brisbane Australia
Hi guys, have a SB stroked, lower half of the block is grouted, closed chamber W2 race heads, 11.25 CR, solid roller cam, it’s mostly street driven but also 1/4 mile ground pounding, I have a PRW mechanical pump but would also like the option of running an electric pump, so, should I get a Moroso or a Meziere pump, which one fella’s???
Re: Which electric water pump ? [Re: crash520] #2589754
12/10/18 11:09 AM
12/10/18 11:09 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I have had great luck with Meziere, I have run it for around 20 years with lots of street miles. I did have an issue with it a few years ago and they repaired it quickly and for a fair price.
If you have the room I would get the higher flow pump, I have the 35GPM and I think the higher flow pump would cool better on the highway. I don't have cooling problems really but my highway situation could be better.
68 Barracuda Formula S 340
Re: Which electric water pump ? [Re: crash520] #2589755
12/10/18 11:12 AM
12/10/18 11:12 AM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
Meziere
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Which electric water pump ? [Re: crash520] #2589758
12/10/18 11:27 AM
12/10/18 11:27 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
I can say from my personal experience with the brands you mentioned, and a couple others, mez would be tops, or stewart emp remote.
In a street car, one of the best systems I've seen is a Stewart modified mechanical, with one of their in line electric remotes in the lower hose.
When/if it gets hot, the remote comes on and blasts it right down.
Re: Which electric water pump ? [Re: crash520] #2589764
12/10/18 12:01 PM
12/10/18 12:01 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Meziere would be my only choice.
Re: Which electric water pump ? [Re: crash520] #2589777
12/10/18 12:40 PM
12/10/18 12:40 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Make sure you get a 45 gal pump and oil cooler..
I like the Meziere pump
wave
Re: Which electric water pump ? [Re: crash520] #2589916
12/10/18 05:11 PM
12/10/18 05:11 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I am curious what most run also. Ron
Re: Which electric water pump ? [Re: crash520] #2589918
12/10/18 05:15 PM
12/10/18 05:15 PM
Brisbane Australia
crash520 Offline OP
crash520  Offline OP
Brisbane Australia
Thanks Gents, appreciate the feedback
Re: Which electric water pump ? [Re: MR_P_BODY] #2589921
12/10/18 05:21 PM
12/10/18 05:21 PM
Brisbane Australia
crash520 Offline OP
crash520  Offline OP
Brisbane Australia
wave
Mr P, my set up is in an E Body, remote filter etc, do you have a preferred/ recommended/suggested oil cooler, brand type size maybe? I have an oily temp sender set up in the pan.
I could place the cooler in front of the right front wheel inside the fender (not preferred due to potential damage from tire pickup etc) the only other place would be lower front balance however I think that would limit me to a cooler only without fan, thoughts anyone?
Re: Which electric water pump ? [Re: crash520] #2589924
12/10/18 05:27 PM
12/10/18 05:27 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
Meziere has always had a good reputation.
I have a Moroso pump for a smallblock,never used it but it looks and feels like a good piece.
Re: Which electric water pump ? [Re: crash520] #2589937
12/10/18 05:44 PM
12/10/18 05:44 PM
MR_P_BODY Offline
MR_P_BODY  Offline
wave
You can look at Summit or Jegs to find a cooler
but you want to look at 1/2" in and out..
you want flow.. B&M makes a nice cooler.. I run
one from the filter using a remote then to the
cooler
wave
Re: Which electric water pump ? [Re: 383man] #2589941
12/10/18 05:58 PM
12/10/18 05:58 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Ron.. this is the price for a SB pump.. this
one is a 42gal pump
https://www.summitracing.com/parts/mez-wp114shd/overview/make/dodge
wave
Re: Which electric water pump ? [Re: crash520] #2590129
12/10/18 11:33 PM
12/10/18 11:33 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
I'm using an oil cooler like this, and it works awesome. It's easier to plumb water lines than oil lines. And it's light.
cooler
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Which electric water pump ? [Re: crash520] #2590218
12/11/18 02:34 AM
12/11/18 02:34 AM
Boise
Moparteacher Online content
Moparteacher  Online Content
Boise
I have CSR reverse flow. Never again. May sell this one and take the hit. PITA. Doesn't purge air. Tried every trick I know. Raised the front end 3 feet in the air, pulled a vacuum on the system to maximize fill. Damn near lost a new engine due to cavitation. I finally installed a zerk fitting next to the pump motor, on top, to bleed air from the vane cavity. Works, buts makes a mess.
I also installed hollow bolts in the cylinder heads on the intake face LF and RR. Drilled through the bottom of the bolt hole into the coolant passage to bleed air from being trapped in the cylinder heads. Crazy how much air was trapped even after I got the coolant flowing. Makes an even bigger mess when bleeding.
CSR makes a quality product, or so it seams, but the reverse flow pump has issues....FWIW
Re: Which electric water pump ? [Re: MR_P_BODY] #2590245
12/11/18 04:29 AM
12/11/18 04:29 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
one is a 42gal pump
wave
Thanks. I keep thinking about trying one some day but I have to be sure it will work good on my street car. I use the stock mech waterpump setup now and have no overheating problems. I do have a backup pusher electric fan in front of the rad for if I get stuck in traffic for a half hr or more as it will keep it from creeping up over 200 on a 95 plus day. I don't know if its worth me trying one since I do mostly street driving ? Thanks , Ron
Re: Which electric water pump ? [Re: Moparteacher] #2590290
12/11/18 11:21 AM
12/11/18 11:21 AM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
Buy this and it will fill and remove air at the same time. Works great.
https://www.tooldiscounter.com/ItemDispl...ASABEgKgSfD_BwE
Re: Which electric water pump ? [Re: crash520] #2590298
12/11/18 11:47 AM
12/11/18 11:47 AM
Martinsville, IN
cdwmotorsports Offline
Martinsville, IN
Meziere. I owned the Moroso and ditched it long ago
eBay-cdwmotorsports
Re: Which electric water pump ? [Re: crash520] #2590378
12/11/18 02:34 PM
12/11/18 02:34 PM
Boise
Boise
"Buy this and it will fill and remove air at the same time. Works great.
https://www.tooldiscounter.com/ItemDispl...ASABEgKgSfD_BwE"
Way ahead of you on that one. I have two different brands. Neither resolved the cavitation problem.
Re: Which electric water pump ? [Re: crash520] #2590400
12/11/18 02:59 PM
12/11/18 02:59 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I have had several of the Moroso units.
The older ones didnt pump a ton of water and were admittedly marginal for street use.
That said, the new ones( been out 4 or 5 years now) pump WAY more water and work fine on the street.
I like how they look, and how they come ready to bolt up to the stock location as opposed to others needing extra plates, etc.
Like anything, the cooling system involves more than just the water pump. Having a good fan and other components are important too.
Both the older style Moroso and this newer one have given me zero issues failure wise in the probably 20 ish years i have now run them.
I wont run anything else. They new ones are great, cool excellent, little cheaper, good looking, and super reliable.
Anybody thst has the newer one i am sure would agree. Nice piece
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Which electric water pump ? [Re: B3422W5] #2590808
12/12/18 12:53 PM
12/12/18 12:53 PM
moparx Offline
moparx  Offline
are there any of the manufacturers using electric pumps as original equipment ? high end rides, sports cars, heavy equipment ?
just wondering.
beer
Re: Which electric water pump ? [Re: moparx] #2590851
12/12/18 02:51 PM
12/12/18 02:51 PM
MR_P_BODY Offline
MR_P_BODY  Offline
just wondering.
beer
Now days almost every car or truck has a electric
pump from the factory
EDIT
Sorry.. I though we were talking FUEL pumps..
water ones just about all 4 bangers have them
but most V-6 and V-8s run mech pumps
wave
Re: Which electric water pump ? [Re: MR_P_BODY] #2591284
12/13/18 01:22 PM
12/13/18 01:22 PM
moparx Offline
moparx  Offline
wonder what GPH a 4cyl water pump would put out ? i'm guessing it would be in line with a hose ? just thinking out loud.
if the package could be small enough, perhaps a pump for each head like a flathead ford ?
beer
Re: Which electric water pump ? [Re: moparx] #2591322
12/13/18 02:45 PM
12/13/18 02:45 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
just wondering.
beer
BMW has had factory remote water pumps for at least the last decade.
PS they are not cheap
Joe
Without Data, you’re just another guy with an opinion.
Re: Which electric water pump ? [Re: crash520] #2591353
12/13/18 03:56 PM
12/13/18 03:56 PM
Boise
Boise
My Chevy Volt has three electric water pumps. They're small and relatively inexpensive.
Re: Which electric water pump ? [Re: crash520] #2592781
12/16/18 02:52 PM
12/16/18 02:52 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I have 2 Meziere SB water pumps 1 black 1 red with block off plate and outlet fitting $300 each shipped email me if interested. Quicktree@aol.com
Re: Which electric water pump ? [Re: Quicktree] #2595400
12/22/18 09:05 AM
12/22/18 09:05 AM
Brisbane Australia
crash520 Offline OP
crash520  Offline OP
Brisbane Australia
Are they used and if so how old, I’d be interested in the black one, has it got a black backing plate?
Shipped to WA
Re: Which electric water pump ? [Re: Quicktree] #2597044
12/26/18 05:29 AM
12/26/18 05:29 AM
Brisbane Australia
crash520 Offline OP
crash520  Offline OP
Brisbane Australia
Tony, my emails have stopped going to you, I’ll pm the address
Re: Which electric water pump ? [Re: crash520] #2597180
12/26/18 03:37 PM
12/26/18 03:37 PM
Q
Quicktree Offline
Quicktree  Offline
Q
PM sent
