Re: Looking for In order of preference ignition system [Re: modelmakerinc] #2592267
12/15/18 12:20 PM
12/15/18 12:20 PM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Re: Looking for In order of preference ignition system [Re: dart4forte] #2592274
12/15/18 12:44 PM
12/15/18 12:44 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
Originally Posted By dart4forte
Originally Posted By dogdays
I'm with you on the analog MSD 6s. My $40.00 secondhand Ebay box just keeps on jammin' sparks. I am using the Direct Connection electronic distributor and a chrome Jacobs coil, really old school stuff.
The major reason that the other guys aren't around any more is that MSD/Holley bought most of them and discontinued them.
There's no reason MSD digital 6 isn't as successful as the analog units, IF you eliminate RFI. The engine compartment has a lot of electrical hash floating around. If the detector circuit in the Digital 6 is too sensitive or isn't selective enough, the box can get triggered by the interference. For that reason most ignition manufacturers encourage you to keep the leads from the mag pickup to the ignition box as short as possible (shorter antenna). As I work with electrical engineers, I have learned that using a twisted pair signal cable can eliminate much of the hash, and a shielded twisted pair just about eliminates it. Something like signal cable used between microphones and mixing boards is the right stuff. Belden 8451 would be a good example. I think the shield should only be grounded on one end. What say you, Sparkys?
R.
Last time I checked MSD is not refurbishing the old boxes. Correct me if I’m wrong.
I had one repaired about six mo.ago.they told me they had no plans to discontiue repairs on 6AL shruggy
Re: Looking for In order of preference ignition system [Re: bonefish] #2592361
12/15/18 03:02 PM
12/15/18 03:02 PM
moparx Offline
moparx  Offline
over the years, i have bought several 6AL's at swapmeets for $5-20, that have worked great ! i know that doing this is a gamble, but i'm guessing the original owners don't know how to troubleshoot electrical systems. shruggy
at present, i have three on the shelf. as there are many RTR setups out there now, i don't know if these will ever get used, but they don't eat much. biggrin
and just yesterday, i found a NIB pro comp type big block distributor [with the chrome cover over the GM HEI unit] i paid a whopping $15 for at a swap, i had completely forgotten about. not sure if it's a b or rb unit. [i didn't measure the shaft] on the shelf it goes ......
beer
Re: Looking for In order of preference ignition system [Re: modelmakerinc] #2592612
12/16/18 12:54 AM
12/16/18 12:54 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
My buddy just had his MSD box repaired about a month ago. Was much cheaper then a new one. Ron
Re: Looking for In order of preference ignition system [Re: Supercuda] #2592873
12/16/18 06:12 PM
12/16/18 06:12 PM
jersey
Spaceman Spiff Offline
jersey
Originally Posted By Supercuda
Dr Jacobs got bought out a long time ago and I don't think anything is available in the US.
I had a Jacobs pro street system on a car 20 years ago.
It would randomly shut off, but then start right back up, and be ok.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
