Re: Pistons for 512ci low deck [Re: dartmeister] #2590407
12/11/18 03:19 PM
12/11/18 03:19 PM
Cab_Burge Online work
Cab_Burge  Online Work
I've built 4 or 5 400 block stroker motors with 4.25 crankshafts with both H beam and I beam rods and two 4.300 stroke crankshafts with internal and external oiling systems, on the five motors I used a stock 3/8 internal pickup I had to grind around .030 to .060 off the pickup boss near the threaded end to clear the front rod scope
Mock up the crankshaft in your block and install the front two rods and pistons with no rings on the pistons and check what grinding, if any,your block will need scope
The stock size Mopar rods need a lot more grinding with the steel H and I beam rods shruggy
Re: Pistons for 512ci low deck [Re: Cab_Burge] #2590448
12/11/18 04:59 PM
12/11/18 04:59 PM
Utah
dartmeister Offline
dartmeister  Offline
Utah
Thats good to know Cab, thanks. I'm on the fence whether to do a 470" or 511" low deck stroker for a street/strip setup. If the 511" is alot more hassles it may not be worth it for the extra 41" for a street car.
Re: Pistons for 512ci low deck [Re: JERICOGTX] #2590452
12/11/18 05:19 PM
12/11/18 05:19 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
440source sells Icon
Re: Pistons for 512ci low deck [Re: 67mprfan] #2590523
12/11/18 07:10 PM
12/11/18 07:10 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Ic837-.033. CNC motorsports had the best price at the time.
Re: Pistons for 512ci low deck [Re: mopar dave] #2590534
12/11/18 07:40 PM
12/11/18 07:40 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
[quote=mopar dave]Ic837-.033. CNC motorsports had the best price at the time.[/quote
Thanks Dave for the info
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: Pistons for 512ci low deck [Re: dartmeister] #2590692
12/12/18 02:12 AM
12/12/18 02:12 AM
I used a four inch body grinder to make my clearances on that boss, piece of cake up wrench
Re: Pistons for 512ci low deck [Re: JERICOGTX] #2590716
12/12/18 03:54 AM
12/12/18 03:54 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Iconn’s in my 451..... been beating them up & down for nearly 10 years now.
