Pistons for 512ci low deck
#2588596
12/07/18 02:17 PM
12/07/18 02:17 PM
Posts: 10,020 MN
JERICOGTX
MN
While walking around PRI, Icon, and Diamond have a "shelf" piston for the 512 B block combo. Anyone have experience with Icon. They look like a very nice piston.
69 GTX
68 Road Runner
Re: Pistons for 512ci low deck
[Re: JERICOGTX]
#2588602
12/07/18 02:22 PM
12/07/18 02:22 PM
Posts: 34,870 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
i have Icon pistons in my 470
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
[Re: JERICOGTX]
#2588668
12/07/18 04:56 PM
12/07/18 04:56 PM
Posts: 43,118 Bend,OR USA
Cab_Burge
I like to use the street alloy, not the looser 2616 alloy , version of any brand pistons on all of my motors. Ross does not make that tighter(edited) alloy so I stop using them I believe all of the Icon brand BB Mopar pistons are the tighter alloy I have used them in several motors now
[Re: Cab_Burge]
#2588694
12/07/18 05:48 PM
12/07/18 05:48 PM
BradH
If by "tighter" you mean 4032 and "looser" 2618, then you need to know which Icon piston series you're looking into. IIRC, the FHR series are 4032, and the others -- including all the BBM stroker pistons I've seen of theirs -- are 2618. Last time I checked, Ross only used 2618; Diamond used both materials, depending upon the application; JE SRPs were 4032, but the "regular" JEs were 2618; RaceTec is 2618 and AutoTec is 4032; Mahle uses both, depending upon the application... etc. Ya gotta do your research. Oh, you can put me in the "Icon pistons are 'OK', but there are others I like better" category. Their big advantage is that they stock a wide variety of BBM bore & stroke options that most other piston companies don't.
[Re: EchoSixMike]
#2590031
12/10/18 08:25 PM
12/10/18 08:25 PM
Posts: 10,020 MN
JERICOGTX
MN
If you want lower clearances, get them with the line to line coating, it's a factory option now. S/F....Ken M Icon told me at PRI, the coating will be standard, once all old stock is bought up.
69 GTX
68 Road Runner
[Re: dartmeister]
#2590110
12/10/18 10:39 PM
12/10/18 10:39 PM
Posts: 2,853 Pattison Texas
CSK
Pattison Texas
For you guys running a 4.25 stroke crank in your lowdeck, are you able to run the stock oil pickup or are you forced to go to an external system? I have the stock one on my 512LD 2.20 rod I had to grind a little
[Re: dartmeister]
#2590112
12/10/18 10:52 PM
12/10/18 10:52 PM
Posts: 4,669 Wichita
GY3
Wichita
For you guys running a 4.25 stroke crank in your lowdeck, are you able to run the stock oil pickup or are you forced to go to an external system? Stock pickup here. 2.20 Molnar rods. The closest area was the pickup boss and it cleared by .060 if I recall... No grinding anywhere.
[Re: GY3]
#2590381
12/11/18 02:34 PM
12/11/18 02:34 PM
Posts: 15 Utah
dartmeister
Utah
For you guys running a 4.25 stroke crank in your lowdeck, are you able to run the stock oil pickup or are you forced to go to an external system? Stock pickup here. 2.20 Molnar rods. The closest area was the pickup boss and it cleared by .060 if I recall... No grinding anywhere. Thank you
[Re: CSK]
#2590382
12/11/18 02:35 PM
12/11/18 02:35 PM
Posts: 15 Utah
dartmeister
Utah
For you guys running a 4.25 stroke crank in your lowdeck, are you able to run the stock oil pickup or are you forced to go to an external system? I have the stock one on my 512LD 2.20 rod I had to grind a little Thank you
[Re: JERICOGTX]
#2590386
12/11/18 02:39 PM
12/11/18 02:39 PM
Posts: 1,030 ohio
67mprfan
ohio
What's the part number for the Pistons you guys are using
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
