front accesory belt #2587508
12/05/18 02:29 PM
12/05/18 02:29 PM
K
Kiddart Offline OP
Kiddart  Offline OP
K
for the front accessory belt what has everyone done with no AC or Power Steering. I think I have read there are Idler pullies available but are they really needed, can you just run belt on alternator, water pump and crank with one tensioner.
If so what belt and can you show picture of front of motor
by the way this is a 2004 5.7 out of a Durango with alt on top passenger side
Thank you
Kiddart
Re: front accesory belt [Re: Kiddart] #2587526
12/05/18 02:59 PM
12/05/18 02:59 PM
Canada
onig Offline
onig  Offline
Canada
I would like to know as well. Mine is same year, same vehicle as yours.
69 Dart
Re: front accesory belt [Re: Kiddart] #2587544
12/05/18 03:31 PM
12/05/18 03:31 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
Dorman Part Number: 18253-09209199 , is the A/C bypass pulley for the 7 rib truck style front cover, for the car cover there is a routing option I don't have it in front of me here, try hitting LX forum I know I've seen a diagram somewhere for both the truck and the car cover, just can't remember where.
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: front accesory belt [Re: Kiddart] #2587628
12/05/18 05:21 PM
12/05/18 05:21 PM
K
Kiddart Offline OP
Kiddart  Offline OP
K
thank you ric3xrt
Thank you
Kiddart
Re: front accesory belt [Re: Kiddart] #2587647
12/05/18 05:53 PM
12/05/18 05:53 PM
K
Kiddart Offline OP
Kiddart  Offline OP
K
I can not fid this on line. would you happen to have a quick pic?
Thank you
Kiddart
Re: front accesory belt [Re: Kiddart] #2587665
12/05/18 06:36 PM
12/05/18 06:36 PM
Arizona
410mopar Offline
410mopar  Offline
Arizona
I did a 2004 truck 5.7 into a Hot Rod. I used the Mopar AC delete bracket 530321AA. I removed the PS pump. I used Gates belt K70776. You reposition an idler pulley. This is all shown on the Mopar instructions. I don't know how to attach that instruction sheet to this post.
Re: front accesory belt [Re: Kiddart] #2587968
12/06/18 09:51 AM
12/06/18 09:51 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
I screwed up the part Number copy and paste from Auto Zone some how,
Google Dorman 34299
https://www.carid.com/dorman/a-c-compres...goaAhrMEALw_wcB
It doesn't list the Durango as an application , only the Rams. 03-08
Re: front accesory belt [Re: Kiddart] #2588058
12/06/18 01:54 PM
12/06/18 01:54 PM
K
Kiddart Offline OP
Kiddart  Offline OP
K
that's the one I felt it was. Thank you so much. off to Auto Zone!!!
Thank you
Kiddart
