Molnar Rods, bearing tangs: user error
#2586188
12/02/18 04:42 PM
12/02/18 04:42 PM
Posts: 17,836 S.E. Michigan
ZIPPY
S.E. Michigan
The cap is installed correctly according to the etched marking on the rod. This is the large chamfer side. One half of the bearing shell is offset significantly from the other half. This causes some of them to touch the journal fillet.
These are 7.100 2.200 .990.
As you can imagine there's alot I could say, However I will give them a call Monday and see what they have to say on this topic.
This very well may be my error, maybe the bearings are specific upper/lower but if that's normal I guess it's my inexperience showing.
Rich H.
Esse Quam Videri
Re: Molnar Rods, bearing tangs
[Re: ZIPPY]
#2586200
12/02/18 05:11 PM
12/02/18 05:11 PM
Posts: 2,853 Pattison Texas
CSK
Pattison Texas
My rod bearing were marked upper & lower
Re: Molnar Rods, bearing tangs: user error.
[Re: ZIPPY]
#2586220
12/02/18 05:51 PM
12/02/18 05:51 PM
ZIPPY
S.E. Michigan
Tom the owner of the company talked to me on Fakebook messenger.....Mind you this is Sunday afternoon....and helped me out.
Perfect storm:
1. User error/my fault not realizing there were separate upper and lower shells. Not sure why this does not ring a bell from the past? But no problem admitting what I don't know or forgot.
2. With that knowledge, I found I have 10 uppers and 6 lowers in the package... that's not gonna work
Following the Direct Connection engine bulletin for old Kellogg cranks, I did their suggested bench mockup of the K1/Molnar when things just seemed....odd.
While it's nice to lay all the pretty looking parts out and so on, but that fillet contact, however slight had me wondering. It did not lock up on the fillet but there was a "drag" and shiny edges here and there had me taking a big step back to look at it.
Lesson learned and case closed for now....I'll order more bearings until I have an actual set of upper/lower, do the whole mockup again and will send the rest of the bearings back.
Thanks!
Rich H.
Esse Quam Videri
[Re: AndyF]
#2586227
12/02/18 06:15 PM
12/02/18 06:15 PM
Posts: 4,663 Wichita
GY3
Wichita
That's the great thing about buying from Molnar. There was a boxing mixup with my crank and I had questions later about rod side clearance during assembly. He was very quick to answer in both instances.
[Re: ZIPPY]
#2586245
12/02/18 07:02 PM
12/02/18 07:02 PM
ZIPPY
S.E. Michigan
I don't do this stuff a lot but enjoy the process as a hobby, and it's a good feeling when you know you got it right. Equally bad feeling when you know it's not right.
Needed a sanity check so went and grabbed some of the stuff I have worked with more recently since that's more fresh in what's left of my brain.
2008 6.1 hemi shown. You just put the bearing in.....
After a few OE part based gen 3 builds I guess I got spoiled and lazy real quick.
No need to care if you have upper or lower, so I stopped caring.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2586347
12/02/18 10:25 PM
12/02/18 10:25 PM
ZIPPY
S.E. Michigan
Cab: that helps, thanks.
I've got next to nothing for BBC experience.
I helped a college classmate rebuild a 454 in the late '80s. That's the last exposure I can remember to a BBC, I did very little to it, and have killed alot of brain cells between then and now.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2586378
12/02/18 11:16 PM
12/02/18 11:16 PM
Posts: 4,205 New York
polyspheric
New York
Toyota does something in engineering that I'm surprised isn't more common. Frequently, a part designed for a specific application will be very close to the best design for a related engine. Many US stuff allows things that should not be interchanged to be swapped over, the poster child may be the 289/210 hp Windsor damper used with a big cam (you need the very different 271 hp damper). Chevy SBC V8 damper fits L6, B/RB early/late tappets and pushrods can be mixed up. Toyota changes at least one feature to make sure if the part is not completely compatible with another engine - it won't go on. They change the bolt pattern of the flex plate and converter when the swap is not a good idea, even in the same transmission. Accidental misapplication is greatly reduced, the downside is everything is more expensive and you don't have the part in stock.
Boffin Emeritus
[Re: ZIPPY]
#2586585
12/03/18 01:45 PM
12/03/18 01:45 PM
Posts: 3,507 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
Tom the owner of the company talked to me on Fakebook messenger.....Mind you this is Sunday afternoon....and helped me out. This doesn't surprise me one bit. One of the reasons I would always recommend using his parts when appropriate.
[Re: ZIPPY]
#2586623
12/03/18 03:11 PM
12/03/18 03:11 PM
Posts: 14,491 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
The only reason there is an upper/lower rod bearing shell in this case is it’s a HP application that needs to have the chamfered side of the bearing towards the large crank filet. If they were oe replacement bearings for that application, there wouldn’t be uppers and lowers.
