On your back transmission jack ?
#2584906
11/29/18 10:48 PM
11/29/18 10:48 PM
Posts: 4,670 On the parachute mount
n20mstr
After doing trans on my back for 35+ years with just a regular floor jack....lol
What's a decent low profile trans jack ? Harbor freight, jegs ? Don't need anything fancy but something that will hold it better than it teetering on a regular floor jack.
....BAD A$$ STREET CAR.....
Re: On your back transmission jack ?
[Re: n20mstr]
#2584918
11/29/18 11:02 PM
11/29/18 11:02 PM
Posts: 43,096 Bend,OR USA
Cab_Burge
My wife bought me a Craftsman all manual tranny jack years ago, I still use it It works great when replacing the tranny with the car on jack stands. A friend of mine has a lot better one (Bendpak brand) for use on a car lift, but I don't really know how well it works, it seems a little wobbly to me EDITED: The one I have is like the 450 Lbs. H.F. shown in Jeremiah post It uses a 1/2 inch ratchet to raise and lowered it, it also tilts some front to rear
[Re: Cab_Burge]
#2584928
11/29/18 11:11 PM
11/29/18 11:11 PM
Posts: 9,096 Rogue River, OR
Jeremiah
Rogue River, OR
I have this and it has been flawless. It's a must have for a stick shift guy. Automatic will be even easier. "800 lb" Trans Jack I wouldn't put 800 lbs on it however it is the only jack we have that does not leak down overnight other than my 10 y/o HF engine crane. They have a few other models to choose from: HF Trans Jacks There are many, many items I insist be made in USA however at my pay scale cranks, rods and jacks come from overseas. We also have a model that inserts into the floor jack. Regardless of how I strap things down it's kind of tippy. I like the dedicated trans jack for all things under the car. It is great for rear axles, etc.
[Re: Jeremiah]
#2584975
11/30/18 12:32 AM
11/30/18 12:32 AM
Posts: 20,144 PA.
pittsburghracer
"Little"John
"Little"John
PA.
[quote=Jeremiah]I have this and it has been flawless. It's a must have for a stick shift guy. Automatic will be even easier. "800 lb" Trans Jack https://www.harborfreight.com/automotive...jack-60234.htmlBuy this one and you won't be sorry. I had the one that goes in a floor jack. Then the cheapie small scissor jack and last year when one almost fell off it bought the Harbor Freight one listed above. It works GREAT.
[Re: n20mstr]
#2584977
11/30/18 12:36 AM
11/30/18 12:36 AM
Posts: 8,018 Tulsa OK
Bad340fish
Tulsa OK
https://www.harborfreight.com/450-lbs-Low-Lift-Transmission-Jack-61232.htmlI have used this one and it works ok. Its not super low profile so on my car you have to put the trans on the jack under the car, which can be kind of a cluster. I stick my electric impact on it and it raises and lowers it great. I recently had the transmission in and out about 10,000 times in a weekend to fit the CSR shield in my A-body. Without this jack it would have been an even more tragic of an experience.
68 Barracuda Formula S 340
[Re: n20mstr]
#2584984
11/30/18 12:46 AM
11/30/18 12:46 AM
Posts: 117 Aus
hysteric
Aus
I'm about to make a cradle that will fit onto the existing jack something similar to this:
[url=http://www.mustangandfords.com/how-to/drivetrain/1804-diy-make-a-transmission-jack-adapter/][/url]
[Re: a493demon]
#2584987
11/30/18 12:52 AM
11/30/18 12:52 AM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
where is that one from ? ^^^^^ I have the 99 dollar one from HF . it's ok .. I'm not exactly sure I Googled the image but looks exactly like the one that I have I want to say I got it from.. Pep Boys about 10 years ago
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: n20mstr]
#2584989
11/30/18 12:57 AM
11/30/18 12:57 AM
Posts: 20,158 Park Forest, IL
slantzilla
Park Forest, IL
I've been lucky enough to pick up 2 really cheap. I have a Blachawk I traded a guy 2 cases of Old Style for, and a Hein-Werner I gave a guy $20 for when he was going to throw it in the steel dumpster at work.
They do make life much easier.
[Re: n20mstr]
#2585030
11/30/18 02:43 AM
11/30/18 02:43 AM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
I can't do it on my back anymore!! But last time I did was the M/C jack.
[Re: n20mstr]
#2585097
11/30/18 11:33 AM
11/30/18 11:33 AM
Posts: 30,989 Oregon
AndyF
I have a transmission jack that I use for transmission work as well as rear ends and pulling the front suspension. Very versatile piece of equipment if you're clever enough to build some attachments.
[Re: Bad340fish]
#2585213
11/30/18 03:24 PM
11/30/18 03:24 PM
Posts: 3,508 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
https://www.harborfreight.com/450-lbs-Low-Lift-Transmission-Jack-61232.htmlI have used this one and it works ok. Its not super low profile so on my car you have to put the trans on the jack under the car, which can be kind of a cluster. I stick my electric impact on it and it raises and lowers it great. I recently had the transmission in and out about 10,000 times in a weekend to fit the CSR shield in my A-body. Without this jack it would have been an even more tragic of an experience. Does anyone make a jack that sits low enough to get a 904 under the car while on the jack with the car on standard jack stands?
[Re: pittsburghracer]
#2585338
11/30/18 08:33 PM
11/30/18 08:33 PM
Posts: 6,840 The Swamp
Sixpak
The Swamp
[quote=Jeremiah]I have this and it has been flawless. It's a must have for a stick shift guy. Automatic will be even easier. "800 lb" Trans Jack https://www.harborfreight.com/automotive...jack-60234.htmlBuy this one and you won't be sorry. I had the one that goes in a floor jack. Then the cheapie small scissor jack and last year when one almost fell off it bought the Harbor Freight one listed above. It works GREAT. I just did the clutch on my NV5600 Cummins with that same jack. Keep in mind it's really meant for flat tranny pan automatics. You have to get creative in order to get it to cradle an oval shaped manual trans case. And I had to modify the chain set up some to get it to be reliable. That NV5600 they say is 400+ pounds and I believe it. It was nice being able to dial in the angle of the trans both vertically and horizontally so the input shaft could go right in. I would not waste money on the cheaper one they sell, the scissor type with the strap.
[Re: hemi-itis]
#2585341
11/30/18 08:41 PM
11/30/18 08:41 PM
Sixpak
The Swamp
I can't do it on my back anymore!! But last time I did was the M/C jack. Ouch...
[Re: n20mstr]
#2585387
11/30/18 10:13 PM
11/30/18 10:13 PM
Posts: 1,134 Lost in Time
Iowan
Lost in Time
Should do a pole here how many of us put transmissions in off our chest I was a helluva lot younger then.
Have a great day Iowan
"obsolete is neat"
