Removal of Trans filter/pan on ZF trans Jeep Grand Cheroke #2584567
11/29/18 08:24 AM
11/29/18 08:24 AM
Adelaide, SOUTH Australia
REDNICK Offline OP
REDNICK  Offline OP
Is there a "special factory " torx key that fits into the gap at the back of the subframe and clears the trans pan for removing the front 4 bolts? Or do the dealers drop the subframe?
Found the trans shop I sent it to for a service did not bother to change the filter, and didnt fill it to the correct level.
Level is now correct , but still has the factory fitted filter . I want put a fresh one in.
2014 Jeep Grand Cherokee eco diesl 8 speed ZF
Re: Removal of Trans filter/pan on ZF trans Jeep Grand Cheroke [Re: REDNICK] #2585122
11/30/18 12:27 PM
11/30/18 12:27 PM
Hershey, PA
73MagDuster Offline
73MagDuster  Offline
Hershey, PA
Sounds like what I experienced on my wife's BMW X5 with the older 6 speed ZF trans. I had to buy a torx bit kit for a cordless drill and hold the bit in while turning it with a 3/8 or so box wrench. It was a PITA. From what I read online the "proper" procedure on the X5 is to drop the rear trans crossmember. This trick saved me a ton of time.
Also, the filter is part of the pan in the older 5 and 6 speed ZF transmissions, don't be surprised if you get a pan when you order the filter. Or if the filter is $$$$$$.
Re: Removal of Trans filter/pan on ZF trans Jeep Grand Cheroke [Re: REDNICK] #2586589
12/03/18 01:57 PM
12/03/18 01:57 PM
enfield, CT
ViperDave Offline
ViperDave  Offline
enfield, CT
mopar didn't worry about the servicing. It was easier to claim it is lifetime fluid
67 Dart GT Vert 273/904
72 Town & Country 440/727
90 D350 reg cab dually cummins
15 Scat Pack Challenger
