hotchkis leaf springs ? Pros an Cons or Eaton Detroit #2580702
11/20/18 05:35 PM
11/20/18 05:35 PM
dracut mass usa
sparcy Offline OP
sparcy  Offline OP
dracut mass usa
I have a 69 charger I am putting leaf spring relocation kit from US car tool .tubing it also. I want a 2 inch drop. How about Eaton Detroit any Pros or cons? It is a street car big block now but mild 5.7 hemi going in. 315 35 20 rubber going on car. Now it has 295 40 18. Thanks
IF YOU ARE NOT WRECKING STUFF YOU ARE NOT LEARNING !
Re: hotchkis leaf springs ? Pros an Cons or Eaton Detroit [Re: sparcy] #2681867
07/27/19 05:52 PM
07/27/19 05:52 PM
dracut mass usa
sparcy Offline OP
sparcy  Offline OP
dracut mass usa
I just did the relocation us car tool on my 1969 charger . I got the 2 inch drop springs from ESOP springs . I am running 345 tire 20x12 rim 6 inch back space . I did not move the inner wheel house aka tub what ever you want to call it . I cut the outer wheel house completely off , and making my own , hanging new 1/4 panels spacing them out a inch or so . inside of tire clears buy over a inch to frame rail . out side almost fit with trimming but I want a real wide body so out I am going . car is at front end shop now getting lined up . I have a 5.7 2012 ram engine with a whipple going in . now working on shock and rear sway bar ideas thinking cicle track rear sway bar . I can send you pics PM me . we are like brothers LOL
