Re: Early big block adjustable rocker arms
[Re: MadMopars]
#2580520
11/20/18 06:04 AM
11/20/18 06:04 AM
Posts: 43,123 Bend,OR USA
Cab_Burge
If your talking about the original ductile iron Mopar adjustable rocker arms found on the 300letter car motors and M.W. motors they do vary from 1.48 up to 1.53 ratio if your talking about the early Isky ductile iron and other brand ductile iron adjustable they vary also RAS use to bush and correct the ratio, even increase them up to 1.62 or so, but if your going to buy a use set and have them fixed why not buy a good new better set to start with like Comp Cams stainless bushed or some good aluminum roller rockers like T&D or Harland Sharp
[Re: MadMopars]
#2580684
11/20/18 05:01 PM
11/20/18 05:01 PM
Posts: 4,457 Washington
madscientist
Washington
Hey Cab, Yes, I was referring to the early 300/MW rockers. I just got a set with a 413 and was curious as to how disappointed I would be if I tried to use them with performance in mind. Wasn't sure if they were similar to the Crane or Isky adjustables overall and/or better than the stamp steel rockers for that matter. I'll measure them out at some point in comparison to the Cranes I have laying around, but given work and the holidays I was hopeful that maybe someone, I.E.(You) had good info on them already to tie me over until I got time to look into them myself. -Trent Run them. They are durable. Most I've tested are accurate. Contact Mike at B3 racing engines and have him hook you up with a geometry correction kit. That will eliminate 99.99% of any valve train issues you would be having.
[Re: madscientist]
#2580711
11/20/18 05:52 PM
11/20/18 05:52 PM
Posts: 20,159 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Hey Cab, Yes, I was referring to the early 300/MW rockers. I just got a set with a 413 and was curious as to how disappointed I would be if I tried to use them with performance in mind. Wasn't sure if they were similar to the Crane or Isky adjustables overall and/or better than the stamp steel rockers for that matter. I'll measure them out at some point in comparison to the Cranes I have laying around, but given work and the holidays I was hopeful that maybe someone, I.E.(You) had good info on them already to tie me over until I got time to look into them myself. -Trent Run them. They are durable. Most I've tested are accurate. Contact Mike at B3 racing engines and have him hook you up with a geometry correction kit. That will eliminate 99.99% of any valve train issues you would be having. Boy Mike has really disappeared hasn't he. I can't remember the last time he posted.
[Re: pittsburghracer]
#2580931
11/21/18 02:55 AM
11/21/18 02:55 AM
Posts: 561 USA
B3RE
USA
Hey Cab, Yes, I was referring to the early 300/MW rockers. I just got a set with a 413 and was curious as to how disappointed I would be if I tried to use them with performance in mind. Wasn't sure if they were similar to the Crane or Isky adjustables overall and/or better than the stamp steel rockers for that matter. I'll measure them out at some point in comparison to the Cranes I have laying around, but given work and the holidays I was hopeful that maybe someone, I.E.(You) had good info on them already to tie me over until I got time to look into them myself. -Trent Run them. They are durable. Most I've tested are accurate. Contact Mike at B3 racing engines and have him hook you up with a geometry correction kit. That will eliminate 99.99% of any valve train issues you would be having. Boy Mike has really disappeared hasn't he. I can't remember the last time he posted. Last week John But, you're right, I haven't been posting much but I do check in fairly often. I just don't have much time to get into any deep discussions of late.
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
