Early hemi lifters
#2580457
11/20/18 01:39 AM
11/20/18 01:39 AM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Anyone familiar with Dodge 270 hemi? Wondering what is available that could be used in this engine. Looking for a solid roller lifter that has a removable tie bar. None of the tie bar lifters I have laying around will fit between the lifter boss and the block deck. I had some old isky rollers that had a removable fork style tie bar, but I have no idea where they are anymore. I could machine a slot in the deck, but Id rather not take any structure out of the deck, as this will be heavily boosted. I have a set of .937 keyway lifters that I could use, but the lifter bosses look a bit thin for bushings. Any suggestions?
Re: Early hemi lifters
[Re: TRENDZ]
#2580610
11/20/18 01:42 PM
11/20/18 01:42 PM
Posts: 7,131 Amarillo, Texas
BBR
Amarillo, Texas
I would contact Nick at www.smithbergracing.comIIRC he has been working on a 270 Dodge lately.
Drag Week 2011 - 77th place - DD Drag Week 2012 - 2nd place SRBB N/A Drag Week 2014 - Kapooya RMRW 2018 RMRW 2020
[Re: BBR]
#2580623
11/20/18 02:10 PM
11/20/18 02:10 PM
dogdays
[Re: TRENDZ]
#2580625
11/20/18 02:12 PM
11/20/18 02:12 PM
TRENDZ
Milwaukee WI
I’ve been in contact with him. Great skills and nice work, but (understandably) secretive on his info on parts/ sources of this stuff. As with anyone good with their craft, there is a long line to wait in for his work. No doubt he is the “go to” guy for the Dodge hemi stuff. I offered to pay his premium for parts I need. No go unless he is doing the build.
I just measured the lifter bosses. I do not feel there is enough material around the lifter bores to open up for the bushings needed for the keway lifters. Looks like I’ll either need to fork one side of a tie bar lifter, or find removable tie bar lifters.
[Re: TRENDZ]
#2580628
11/20/18 02:23 PM
11/20/18 02:23 PM
TRENDZ
Milwaukee WI
I’ll have to call hotheads about the lifters. Ther dont show them or list any info about them. Here is a pic of what came with this basket case. Strange stuff...
[Re: TRENDZ]
#2580692
11/20/18 05:10 PM
11/20/18 05:10 PM
Posts: 4,457 Washington
madscientist
Washington
I’ll have to call hotheads about the lifters. Ther dont show them or list any info about them. Here is a pic of what came with this basket case. Strange stuff... That's a bit before my time, but...that may be a Chet Herbert deal. I've seen similar pictures (been a few decades back) and it seems Herbert was doing stuff like that. I may have some info in my old Direct Connection books on the early hemi stuff. You may have to call Doug Herbert and talk to him. Also, I wouldn't b afraid to call Isky and see if you can send some pictures to Ed and let him look at them. He's been there since almost the word go. Just spit ballin' here.
[Re: TRENDZ]
#2583684
11/27/18 02:37 PM
11/27/18 02:37 PM
BBR
Amarillo, Texas
I wonder if those are the Harley-based roller lifters that I have read about?
0.73" (ish) lifter body with a sleeve to adapt it to the .904" lifter bore.
[Re: TRENDZ]
#2583736
11/27/18 04:23 PM
11/27/18 04:23 PM
TRENDZ
Milwaukee WI
Now that you say that, they do look like a harley roller. Im not looking for a new set of these though. Just looking for .904 lifters that can be separated.
[Re: TRENDZ]
#2583751
11/27/18 04:52 PM
11/27/18 04:52 PM
Posts: 17,800 S.E. Michigan
ZIPPY
S.E. Michigan
I had some old isky rollers that had a removable fork style tie bar, but I have no idea where they are anymore. That comment rings a bell, I was told by someone at Engle their Chrysler tie bars had the "double open end wrench" style tie bar. Maybe Engle is worth talking to in addition to Isky.
Rich H.
Esse Quam Videri
[Re: TRENDZ]
#2583863
11/27/18 09:07 PM
11/27/18 09:07 PM
crabman173
crabman173
Steen in NW USA makes the decent rollers that Herbert used to sell Herbert is no longer in business don't order from there but I have used 829-16 comp 440 solids in early Hemi before--they are solid body and tall enough to work Rueben Cams in Calif used to grind all of Herberts stuff and they have the cores --know the grinds and may be able to supply the lifters as well or see Rickys garage om Youtube --he is west coast early hemi Guru and can supply lifters easy as pie I bet Why mess with that dinosaur stuff pictured--they belong in the Garlits Museum
[Re: TRENDZ]
#2583894
11/27/18 10:16 PM
11/27/18 10:16 PM
TRENDZ
Milwaukee WI
Thanks for the leads! I have no intention on using the lifters I posted. Just thought Id share what I was dealing with. I didn’t think anyone would have roller cam cores for the Dodge low deck. From what I have been able to gather, the 241/270 low deck blocks have different lifter bank angles compared to the 315/ 325 inch tall decks. That in itself scares me. Looking for a cam grinder that knows that there is a difference may be difficult. I looked into making 3 billet UGL cores. They don’t need the gear, so they would be simple to make. Just not sure about the treatment/ metallurgy that goes into a core. Again, thanks everyone for your help.
[Re: TRENDZ]
#2583907
11/27/18 10:33 PM
11/27/18 10:33 PM
crabman173
crabman173
On that there would be no better than ISKY to check with --They will Know for sure Good luck! Save the old core maybe getting it reground as solid thumper will be best option--maybe skip roller
[Re: TRENDZ]
#2583920
11/27/18 10:56 PM
11/27/18 10:56 PM
Posts: 8,156 Plymouth, MI
Blusmbl
Plymouth, MI
Google searching it comes back with a surprising number of hits to the HAMB. Lots of people seem to indicate you can use LA lifters in the early Hemis, they are close enough to work for flat tappets and hydraulic tappets. I don't know if there are any LA lifters with adjustable tie bars though, you may have to slot them yourself. https://www.jalopyjournal.com/forum/threads/dodge-270-with-adjustable-rockers.565160/Also: Now that you say that, they do look like a harley roller. Im not looking for a new set of these though. Just looking for .904 lifters that can be separated. The bottom one looks like a Harley panhead lifter with the adjuster removed. From what I understand, the last gen twin cam Harley lifters are LS Chevy pieces too.
