Do the A518 & the 66RFE share the same bolt pattern? #2580444
11/20/18 01:22 AM
11/20/18 01:22 AM
Kerikeri, NZ
jacb Offline OP
jacb  Offline OP
Kerikeri, NZ
Does anyone know if the bellhousing bolt patterns on the 66RFE and the A518 are the same?
If they are would the JVX http://jvxracing.com/Adapters.htm or SMR http://smrtrans.tripod.com/smrtransmissionsintro/id9.html adapter plates mount the 66RFE to my Mopar B/B 440 RB?
Re: Do the A518 & the 66RFE share the same bolt pattern? [Re: jacb] #2580480
11/20/18 02:44 AM
11/20/18 02:44 AM
A727Tflite Offline
A727Tflite  Offline
All 518 except diesel share the same bellhousing patterns as the RFE.
