66RFE to J W Performance Ultra-Bell - Can it be done? #2580440
11/20/18 01:13 AM
11/20/18 01:13 AM
Kerikeri, NZ
jacb Offline OP
jacb  Offline OP
Kerikeri, NZ
I would like to put a 66RFE Transmission behind my Mopar B/B 440 RB in a similar fashion to the A518 shown in the post "Big block a518 overdrive conversion (lots of pics)" posted on this forum some time ago.
See: https://board.moparts.org/ubbthreads/ubbthreads.php/topics/35994/1.html
I have been in touch with JW and they are not sure if it is possible using their Ultra-Bell #92457 "Big Block Chrysler to TF727 or A518".
My question is ….is the bolt pattern/size of the A518 pump the same as the 66RFE pump?
Can I cut off the 66RFE's bellhousing and use JW part#92457 as if it was an A518?
The plan is to then use a PCS 2800 to control it.
Re: 66RFE to J W Performance Ultra-Bell - Can it be done? [Re: jacb] #2580443
11/20/18 01:20 AM
11/20/18 01:20 AM
A727Tflite Offline
A727Tflite  Offline
There is no likeness between the 518 and RFE pumps.
Only way I can see you using the RFE family would be to use an adapter or cut the bell off and weld a 727 bell on.
You need a stand alone controller to run any RFE trans - they are completely electronically controlled.
Re: 66RFE to J W Performance Ultra-Bell - Can it be done? [Re: A727Tflite] #2580453
11/20/18 01:31 AM
11/20/18 01:31 AM
Kerikeri, NZ
jacb Offline OP
jacb  Offline OP
Kerikeri, NZ
Thanks Transman according to transmissiontuner.com the PCS TCM-2800 with a "helper Module" of his own design can be used to control the 66RFE http://www.transmissiontuner.com/68RFE-Swap.html
Re: 66RFE to J W Performance Ultra-Bell - Can it be done? [Re: jacb] #2580454
11/20/18 01:37 AM
11/20/18 01:37 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Did you read the whole article? there is a lot involved in that set up.
Re: 66RFE to J W Performance Ultra-Bell - Can it be done? [Re: A727Tflite] #2580455
11/20/18 01:38 AM
11/20/18 01:38 AM
Kerikeri, NZ
jacb Offline OP
jacb  Offline OP
Kerikeri, NZ
Thanks Transman
Do the pump bolts share a common PCD?
Would you happen to have a photo of the two pumps to help me appreciate the differences?
Re: 66RFE to J W Performance Ultra-Bell - Can it be done? [Re: stumpy] #2580458
11/20/18 01:39 AM
11/20/18 01:39 AM
Kerikeri, NZ
jacb Offline OP
jacb  Offline OP
Kerikeri, NZ
Thanks stumpy
Yes I have read the entire article …. its not a Sunday afternoon job.
Re: 66RFE to J W Performance Ultra-Bell - Can it be done? [Re: A727Tflite] #2580459
11/20/18 01:44 AM
11/20/18 01:44 AM
Kerikeri, NZ
jacb Offline OP
jacb  Offline OP
Kerikeri, NZ
Transman do you know if the A518 & the 66RFE share the same bellhousing bolt pattern?
Re: 66RFE to J W Performance Ultra-Bell - Can it be done? [Re: jacb] #2580478
11/20/18 02:39 AM
11/20/18 02:39 AM
A727Tflite Offline
A727Tflite  Offline
It’s my understanding that 318/340/360/5.7/6.1/6.4/6.7 share the same bellhousing bolt pattern.
Been over two years since I left Chrysler and if memory serves me that was a fact back then.
Now, the 518 has a cast iron pump held in the bell.
All RFE has a “hub cap” that covers the internal pump and is held in place with a snap ring.
Look inside a RFE bell and all you will see is that hub cap.
The pump is an aluminum body bolted to the case behind that cover.
Pump and bell pics [Re: jacb] #2580481
11/20/18 02:51 AM
11/20/18 02:51 AM
A727Tflite Offline
A727Tflite  Offline
Here are pics
Re: Pump and bell pics [Re: jacb] #2580582
11/20/18 12:40 PM
11/20/18 12:40 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
You might be able to use a JVX adapter to bolt the trans to the engine. Getting the converter connected to the crank might take some creative machine work but should be doable I would think.
http://jvxracing.com/Adapters.htm
Kevin
