Re: 904 smooth alto's in the front drum?
[Re: hysteric]
#2580206
11/19/18 02:42 PM
11/19/18 02:42 PM
Posts: 11,408 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
They really should be grooved. The oil has to escape from between the frictions and steels to get them applied.
[Re: hysteric]
#2580329
11/19/18 08:48 PM
11/19/18 08:48 PM
Posts: 117 Aus
hysteric
Aus
In the front drum Doug?
Spoke to the other supplier about alto thin smooths in the front clutch and his response was it made for a soft/mushy 2-3 change.
[Re: hysteric]
#2580383
11/19/18 11:17 PM
11/19/18 11:17 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I believe I said they were interchangeable when the OP was questioning if they would fit size wise, tooth pattern, etc. The OE stuff years ago was specific material, groove pattern and thicknesses for the front and rear clutches. Now the aftermarket supplies a variety of performance materials, grooves and thicknesses. Blue Plates and performance frictions from Raybestos, Altos, Borg Warner, smooth, grooves, waffle, etc. I'm sure everyone has their own preferences and favorites.
[Re: hysteric]
#2580398
11/19/18 11:42 PM
11/19/18 11:42 PM
Posts: 9,791 MI, usa
dvw
MI, usa
Yes in the front drum. I actually run the stock ones in the rear drum. No issue with the shifts. Doug
