Page 5 of 9 1 2 3 4 5 6 7 8 9
Re: Hemi block casting dates [Re: curbman68] #2469235
03/20/18 04:57 PM
03/20/18 04:57 PM
A727Tflite Offline
A727Tflite  Offline
Have a :
3/9/65 casting date
393 stamped on the passenger side pan rail ear
+ - 19 - 65 assembly date
NH 380 on the top pad
This is a Nascar block with the safety wired core plugs
Re: Hemi block casting dates [Re: curbman68] #2469239
03/20/18 05:00 PM
03/20/18 05:00 PM
A727Tflite Offline
A727Tflite  Offline
Hemicar71 - to post pictures on Moparts have them on your device, open a post, click on Switch to Full Reply below the posting area, once there notice again below the posting area "file manager". Click that and then browse to your images and then attach.
Simple and freeeeeeee.......
Re: Hemi block casting dates [Re: curbman68] #2469272
03/20/18 06:06 PM
03/20/18 06:06 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
1971 HEMI E BODY REGISTRY
Re: Hemi block casting dates [Re: curbman68] #2469329
03/20/18 07:39 PM
03/20/18 07:39 PM
A727Tflite Offline
A727Tflite  Offline
Test
Re: Hemi block casting dates [Re: curbman68] #2469330
03/20/18 07:41 PM
03/20/18 07:41 PM
A727Tflite Offline
A727Tflite  Offline
Hemicar71 - you are correct - something is broke. Just tried it and no soap.
Sorry - it normally works as easy as I posted.
Maybe the moderators will see this and have it corrrcted.
Ok, I tried again and it worked. Not sure what is going on.
Re: Hemi block casting dates [Re: A727Tflite] #2470693
03/22/18 09:30 PM
03/22/18 09:30 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
Know of
4-6-64
5-16-74
Re: Hemi block casting dates [Re: curbman68] #2577971
11/13/18 04:25 PM
11/13/18 04:25 PM
Green Lane, PA
sawdust Offline
sawdust  Offline
Green Lane, PA
Here is the fifth block cast. Was done on 10/18/1963 The early ones had some interesting features, looked more like a modified max wedge block which they were apparently.
Re: Hemi block casting dates [Re: curbman68] #2578061
11/13/18 07:58 PM
11/13/18 07:58 PM
Stuttgart, Arkansas
rickseeman Online content
rickseeman  Online Content
Stuttgart, Arkansas
There is supposedly some on 10-17-63
2011 Drag Pak Challenger
Re: Hemi block casting dates [Re: curbman68] #2578305
11/14/18 11:52 AM
11/14/18 11:52 AM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
The casting date of 10-17-63 is the earliest block I have seen and it is on the list I had posted earlier.
Re: Hemi block casting dates [Re: curbman68] #2578633
11/15/18 02:50 AM
11/15/18 02:50 AM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
http://www.thehemi.com/forums/viewtopic.php?t=3481
If the link shows up here is a picture of 10-17-63 Hemi Block. I think Kirkpatrick owns the block. I have a set of the first heads cast.
Re: Hemi block casting dates [Re: ScottSmith_Harms] #2580021
11/18/18 11:07 PM
11/18/18 11:07 PM
Orlando, FL
ChargerKnight66 Offline
Orlando, FL
I also have one with a 1-17-66 casting date that's a BH 426.
Can't figure out how to post a picture of it.
Re: Hemi block casting dates [Re: ChargerKnight66] #2580084
11/19/18 02:59 AM
11/19/18 02:59 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Must have cast a bunch of 1-17-66 blocks, I have two and both are replacements with no stampings, have also seen 7 others, some assembled BH426 (2), some CH426 (3) and 2 built for 68's with stamped in VINs.
Re: Hemi block casting dates [Re: ScottSmith_Harms] #2774482
05/14/20 12:05 PM
05/14/20 12:05 PM
tennessee,usa
mattsmopars Offline
mattsmopars  Offline
tennessee,usa
This engine was for sale the other day. Appears to be a 8-18-69 casting.
Matt
Re: Hemi block casting dates [Re: FC7cuda] #2774656
05/14/20 08:30 PM
05/14/20 08:30 PM
Mobile Al
hemirdrnnr Offline
hemirdrnnr  Offline
Mobile Al
Originally Posted by FC7cuda
10-31-66. Spooky isn’t it?
My 68 roadrunner has this date also.
Re: Hemi block casting dates [Re: hemirdrnnr] #2775067
05/16/20 10:06 AM
05/16/20 10:06 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
So glad I came upon this read, amazing history. So from what I read my car a 66 Belvedere early Jan build, the block would have been cast in August of 65? None where cast again till 1/20/66 (too late for mine) is this correct?
Re: Hemi block casting dates [Re: cudaman1969] #2776142
05/19/20 02:13 PM
05/19/20 02:13 PM
Stuttgart, Arkansas
Stuttgart, Arkansas
Yes. Most likely 8-16 or 8-17. But not impossible to be 3-9.
Re: Hemi block casting dates [Re: rickseeman] #2776545
05/20/20 05:35 PM
05/20/20 05:35 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Thanks, now I know what to search for.
Hello, any out there for sale?
Re: Hemi block casting dates [Re: MikeN] #2918549
05/04/21 05:10 PM
05/04/21 05:10 PM
WINDSOR
Bow Duke Offline
Bow Duke  Offline
WINDSOR
What do you all think of this block? I did not see this cast date on the lists.
Re: Hemi block casting dates [Re: Bow Duke] #2918718
05/05/21 12:36 AM
05/05/21 12:36 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
That block is somebody's attempt at stamping the I.D pad of a factory over the counter block (1974 casting) so that it would appear to be an original Race Hemi block. (1967-68 vintage).
Re: Hemi block casting dates [Re: ScottSmith_Harms] #2918735
05/05/21 06:34 AM
05/05/21 06:34 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
That stamping kind of looks like factory fonts to me. I wonder if it was a complete over the counter built hemi from some of the later cast hemi blocks. I know they were still casting blocks till the mid 70’s. Did they stamp the pad on those over the counter blocks?
