AEM afr gauge wiring #2577829
11/13/18 08:06 AM
11/13/18 08:06 AM
BeavisHQV Offline OP
Ordered an aem afr gauge (AEM 30-0300) that should arrive soon.
Think i have to hook up a 12 volt switched source + ground. Whats the best way to hook this up. Some says directly to the fusebox but i think upstream with a inline fuse to the fusebox would be better. So where to you guys get your ign 12 volt + ground. Pics would be a appreciated.
THX
Re: AEM afr gauge wiring [Re: BeavisHQV] #2577838
11/13/18 09:59 AM
11/13/18 09:59 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
i use one of those and the directions were pretty clear and complete.if im not mistaken ( its been awhile) i just hooked it up to a switched source.wait till you get it and see what hey want you to do and if you have any questions ill look at mine and try to be more helpful up
