Re: Recommend an intake for my 499" RB
[Re: DaveRS23]
#2577918
11/13/18 02:09 PM
11/13/18 02:09 PM
Posts: 13,354 Marion, South Carolina [><]
an8sec70cuda
The Holley Street Dominator will get you more hood clearance if that's an issue. It runs basically the same as the Performer RPM even though it's a single plane. Very good manifold.
[Re: fast68plymouth]
#2577922
11/13/18 02:24 PM
11/13/18 02:24 PM
BradH
If you want less stall, you just need to use a bigger converter.
I’d be pretty surprised if a factory 12” converter stalled over 4K behind that motor. I’d be pretty surprised if a factory 12” converter held up behind that motor. Perhaps your comment was an observation, rather than a recommendation.
[Re: DaveRS23]
#2577991
11/13/18 05:24 PM
11/13/18 05:24 PM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
It was more of an observation, but if that’s what you needed........I’m sure a factory 12” converter could be made to live behind a motor like that.
I’m also confident an 11” could be tightened up enough to stall below 4200.
[Re: an8sec70cuda]
#2577996
11/13/18 05:38 PM
11/13/18 05:38 PM
Posts: 4,667 Wichita
GY3
Wichita
The Holley Street Dominator will get you more hood clearance if that's an issue. It runs basically the same as the Performer RPM even though it's a single plane. Very good manifold. X2! This is the intake I run and I have room for 1/2" spacer and a nitrous plate and it still fits under my stock hood with a drop base air filter. Stock Street Dominator is good but ported is better!
#2577997
11/13/18 05:39 PM
11/13/18 05:39 PM
GY3
Wichita
I’m also confident an 11” could be tightened up enough to stall below 4200. I run an 11". Works really well!
[Re: DaveRS23]
#2578145
11/13/18 11:01 PM
11/13/18 11:01 PM
Posts: 12,013 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I spoke to several converter guys about this. I have a couple of 12" converters here for cores. Apparently, there are no internals available for them for this kind of build.
And they said the 11" are hard to find and expensive because some of the racers scoop them up when they come up. So we're basically stuck using the too small 10" stuff because there are cores and internals readily available for them.
I am just reciting what the converter builders have told me.
As to the intake, I have a Street Dominator. Good intake. But I converted it to Dominator flange years ago and it looks like it would be a chore to shrink back down to 4150.
So it looks like the RPM is the first choice for many here. Followed by the Indy dual plane and then the Holley.
Probably all good intakes that will do the job AND fit under the hood with a 4150 and maybe a drop base air cleaner.
Master, again and still
[Re: DaveRS23]
#2578163
11/13/18 11:25 PM
11/13/18 11:25 PM
Posts: 4,311 Prospect, PA
BSB67
Prospect, PA
440 2D gets my vote. It will be the same height as the RPM, and will make more power. The SD will match the 440 2D in power, but despite the 500+ in motor, the single plane SD is softer below 3500.
I have 1900 stall and a 3.23 in a 4150 lb car with the 440 2D.
I shift 6300-6500 rpm, FWIW
[Re: Lee446]
#2578190
11/13/18 11:58 PM
11/13/18 11:58 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
In my case, the adapter wouldn't let it all fit under the hood.
Call any of the Mopar oriented converter guys and they can give you the skinny on your converter. I think that it is one I would have loved to have had as a core this last go-around.
[Re: Lee446]
#2578216
11/14/18 12:56 AM
11/14/18 12:56 AM
Posts: 43,118 Bend,OR USA
Cab_Burge
Mopar made many different version of both the 12 and 11 inch "stock OEM" converters, including the highest stall 11 inch 1970 383 2 barrel motor in the C bodies to street hemi and on the 12 inch motorhomes from low stall 35 Ft Class A chassis to the 1968 and up 318 class B chassis converters I had a SS/AH race Hemi T/A 8 inch converter in my old pump gas Duster that worked absolutely excellent on the street it was tight at light throttle in town driving and would stall around 5200 RPM at the track in low gear on the hit That was a really good converter for me
[Re: DaveRS23]
#2578299
11/14/18 11:21 AM
11/14/18 11:21 AM
Posts: 409 Texas
mprhound
Texas
I would use this https://www.summitracing.com/parts/hly-0-80805hbx/Holley 0-80805HBX - Holley Aluminum Ultra XP Carburetors Click here for more information about Holley 0-80805HBX - Holley Aluminum Ultra XP Carburetors Free Shipping Carburetor, Ultra XP, Race, 950 CFM, 4-Barrel, Grey Body, Black Anodized Metering Blocks, Each Estimated Ship Date: Today $896.95 Qty Add To Cart And a 337 intake PM me; I have a new in the box 337 and the aforementioned carb (with 2 Drag weeks on it) that I would turn loose as a package deal
[Re: Lee446]
#2578323
11/14/18 12:34 PM
11/14/18 12:34 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I was not clear Dave, if you need the core, let me know. Thank you, Lee. I would have liked to have had that core last year when I went through my last converter change. But I am done with pulling the thing apart......at least I hope I am. I have had the engine and tranny back out twice dealing with this converter issue. It is much better now. To the point that I can live with it. Cab, I am at the point now where the vast majority of the car's time is spent cruising and just driving around. And I like my street cars crisp down low. All of the converters worked okay, they were just too soft (mushy) down low for my liking. What little track time I do, 4,000+ flash gets the car into the 1.5s 60ft. Not too bad for a street car. Plus, I don't tear up as many parts as I would with more flash. Lenny at Ultimate took the time to discuss what I wanted and recommended changes to my car. Then took my PTC converter and made some changes to it. PTC, who built the converter and tried a second time to tighten it up, said there was nothing more they could do. For less than $300 total, including shipping, Lenny made a real difference. Much tighter, crisper, and more responsive down low. Thank you Lenny at Ultimate!
[Re: DaveRS23]
#2578332
11/14/18 12:53 PM
11/14/18 12:53 PM
fast68plymouth
So. Burlington, Vt.
In light of the 10” converter, I think either the RPM, Holley SD, or an M1 single plane would work just fine.
The RPM would be a bit sharper on the bottom, the single planes should be a bit better up high.
I wouldn’t expect big differences between any of them though.
I’d top it off with a 1.45 x 1.75 4150 carb.
I’m sure a spacer would be worth something, and in that regard the Holley is the lowest, so it would have the most available room to use a spacer on.
#2578537
11/14/18 09:59 PM
11/14/18 09:59 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I agree with that. But just out of curiosity, why did you leave the Indy off your list?
Like I said before, I have a Holley intake now, and I have always had good luck with them, although I have never heard much about them from other guys. But I cut this one for a Dominator years ago. I will pull it out and see just how hard it would be to shrink back to 4150 dimensions.
[Re: DaveRS23]
#2578582
11/15/18 12:01 AM
11/15/18 12:01 AM
fast68plymouth
So. Burlington, Vt.
The only reason I left the Indy 440-2D off the list was I don’t know that I feel it’s better enough to justify the added cost over the other 3 when used with std port heads.
