Re: E-body front anti-sway bar size
[Re: GoodysGotaCuda]
#2577369
11/12/18 01:25 AM
11/12/18 01:25 AM
Posts: 3,485 Annapolis, MD, USA
Vert
Annapolis, MD, USA
Not sure. Solid iron bar, similar profile to stock. Pretty sure shims would be of no help here. Thought it was a Hemi bar from Mopar, but just doesn't want to go thru the k-frame.
[Re: Vert]
#2578005
11/13/18 06:08 PM
11/13/18 06:08 PM
Posts: 1,440 NW Chicago suburban area
Mopar Mitch
Vert -- I've experienced problems fitting my 1.25 front sway bar through the k-frame of my e-body. IF the k-frame has been ever so slightly bent up (reduced in passage way size), then yes, you will have problems making a 1.25" bar fit through it. In fact, some of the aftermarket "hollow" front 1.25 sway bars (I know Firm Feel's 1.25 is actually 1-5/16) actually measure their diameter closer to 1-5/16"... and then more fitting problems!
Spreading the k-frame to open up more is very difficult... needs to be torched/heated and then spread with a hydraulic spreader... that's how I had mine done after trying without a torch.
Or else you could just try a 1-1/8 dia sway bar. BUT, IF the area has been crushed, then you'll have to make a decision.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: Mopar Mitch]
#2578200
11/14/18 12:13 AM
11/14/18 12:13 AM
Vert
Annapolis, MD, USA
Great info Mopar Mitch. Its an Al Debevic converted Hemi K-frame. Not bent or crushed. Just too tight for the bars I have. Think I'll try the mockup if I can find some 1 and 1/8ths conduit. I can't bring myself to cut the welds after spending the bucks for powdercoating.
