my jeep from hell
#2577017
11/11/18 03:41 AM
11/11/18 03:41 AM
Posts: 954 garnett kansas
rhad
garnett kansas
we bought a 2002 jeep grand cherokee recently,on the way home we stopped to eat lunch(chinese buffett),after lunch it wouldnt start,after using the remote door lock several times to no avail i tried the key in the drivers door to lock and unlock,IT STARTED!!!,since then (a couple weeks) the transmission went south (42RE),i was replacing the brake pads on all four wheels,did you know jeep had two different caliper designs that year on the front!!!,ordered new calipers for the rear and while pushing the piston back in on the old rear calipers the brake line that goes to the rear decided to exit fluid all over the floor due to rust,so i replaced it,now have great brakes,also put on a new set of tires,and of course when the transmission was being done the coolant lines were so rusted that they had to be replaced,so finally we thought it was all ok,nope!,went on a short trip and the security key light was ojn most of the way,on the return trip it was off ,so today it started right up,wife run a errand and locked it with the remote,it took several tries both with the remote and using the key in the door to get it home,now after several tries it will start and die (part of the security im told)im going to check the ecm plugs for corrosion tomorrow, as well as clook at the grounds ,if i can get it to start im seriously thinking of sending in the ecm and having the security disabled,then i can unplug the SKIM module and MAYBE it will be safe to drive!!,im open to any ideas or help i can get!!
my ladder of success is missing some rungs
Re: my jeep from hell
[Re: rhad]
#2577107
11/11/18 02:14 PM
11/11/18 02:14 PM
rhad
garnett kansas
so this morning i locked and unlocked the drivers door twice and it started right up,i think its time to disable the security in this jeep,what say you?
[Re: rhad]
#2577263
11/11/18 09:31 PM
11/11/18 09:31 PM
Posts: 8,667 Buford, GA
I_bleed_MOPAR
Buford, GA
IMHO, I would do it. I'm about to pull the dash in my Durango to replace the blower motor (and heater core, evap. core, and resistor while it's out) and think I'll disable mine while in there. I've been lucky- owned it for 2 1/2 yrs. now and only had the alarm go off twice when opening the hatch. Ran to the drivers door both times to shut it off. Now I just unlock one of the front doors to disable the alarm before opening the hatch. PO didn't have the remotes but called after I left saying he had found one and would mail it to me. Guess what never showed up? I wasn't too worried about it so I never called him about it. I had printed out the way to disable the alarm on mine. Guess I need to find it. IIRC, on mine all you have to do is ground one wire in the L kick panel? Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
[Re: poorboy]
#2577384
11/12/18 02:26 AM
11/12/18 02:26 AM
rhad
garnett kansas
Gene,i knew there was things it needed,thats a givin on a used car,its the theft alarm that is givin me nightmares,as for the undercarriage,it was sold new in ohio ,so that should tell you something!!,outside is nice and clean as is the inside,underneath the rust worms have been doin some damage,ive seen a lot worse,but they were plow trucks!!
[Re: poorboy]
#2578238
11/14/18 02:17 AM
11/14/18 02:17 AM
rhad
garnett kansas
i got the ECM out today getting ready to send it in for a SKIM delete,turns out its a mopar reman sold on June 2018,so i guess i got bent over big time as nothing was mentioned about problems with the security when i bought it if i wasn't so crippled up i would have looked underneath and seen the rust,and if i would have drove it i would have known it was starting out in second all in all it should be a nice jeep after i get the money pit full!1
[Re: rhad]
#2579024
11/16/18 02:42 AM
11/16/18 02:42 AM
rhad
garnett kansas
i got the PCM sent off for a SKIM delete today,and im smelling antifreeze and the overflow jug is low,hope its not the radiator,i need a easy fix this time,the heater core needs a backflush as it only puts out lukewarm air,gee,i wonder whats next?
[Re: DaytonaTurbo]
#2588421
12/07/18 02:30 AM
12/07/18 02:30 AM
rhad
garnett kansas
i should have the ecm back in a few days,then we will see what other problems pop up,im gonna backflush the heater core with hot oxi clean pumped thru it
[Re: rhad]
#2588739
12/07/18 07:44 PM
12/07/18 07:44 PM
Posts: 41 Maryland
regularjay
Maryland
Had similar issue with my 2002 Jeep WJ, I removed the ASD rely and jumped it out, viola! no more SKIM problems. I believe the SKIM activates said relay to allow fuel & ignition to work, jumping the relay contacts accomplishes the same thing - fuel and ignition are still ultimately turned on-off by the key anyway.
I'm sure some nervous nellie will be chiming in to tell me how terrible my "fix" is, I don't care, it's been working fine for over a year.
79 Lil Red Express - I'll finish it someday 94 2wd Ram 1500 5.9 Donor for...??? 78 CJ7 4.2 with Clifford Cam, Holley 390, 4" on 33's 1992 W250 Cummins 2013 Ram 4X4 Hemi Crew Express 2005 Ex Cab Dakota 4x4 4.7 Daily Driver 1993 2wd Ramcharger 5.2/auto
[Re: regularjay]
#2588923
12/08/18 02:59 AM
12/08/18 02:59 AM
rhad
garnett kansas
looks like ill get the ecm back on monday via USPS,then ill find out if the BCM has a player in this cluster#%&*
[Re: rhad]
#2590200
12/11/18 02:03 AM
12/11/18 02:03 AM
rhad
garnett kansas
i got it goin 2day,no security problems now!!!, t stat and heater flush 2morro
