Re: New Holley Street Avenger Carb Question
[Re: 440mopar]
#2576852
11/10/18 07:33 PM
11/10/18 07:33 PM
Posts: 1,048 The Great White North
RAMM
I have never and I mean NEVER seen one of those carbs run correctly. Avoid. J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
[Re: RAMM]
#2576882
11/10/18 08:52 PM
11/10/18 08:52 PM
Posts: 5,587 Detroit area
6PAX
Detroit area
I have never and I mean NEVER seen one of those carbs run correctly. Avoid. J.Rob Are you referring to just the 670 version or any Street Avenger carb.? I have had a 770 Street Avenger on my car for nine years and it has run perfectly from day one.
[Re: 6PAX]
#2577049
11/11/18 10:49 AM
11/11/18 10:49 AM
RAMM
I have never and I mean NEVER seen one of those carbs run correctly. Avoid. J.Rob Are you referring to just the 670 version or any Street Avenger carb.? I have had a 770 Street Avenger on my car for nine years and it has run perfectly from day one. I hope you buy lottery tickets because I have never seen ANY Avenger series carb run properly. In fact I have had many come in for dyno testing and we cannot even perform one safe pull. You can play with jetting all day and it won't make a difference. Something is messed up with the metering blocks and I have never looked into as time is $$$. J.Rob p.s. I bet if you put a regular and known good double pumper on you would see what you have been missing out on.
[Re: RAMM]
#2577062
11/11/18 12:16 PM
11/11/18 12:16 PM
6PAX
Detroit area
I have never and I mean NEVER seen one of those carbs run correctly. Avoid. J.Rob Are you referring to just the 670 version or any Street Avenger carb.? I have had a 770 Street Avenger on my car for nine years and it has run perfectly from day one. I hope you buy lottery tickets because I have never seen ANY Avenger series carb run properly. In fact I have had many come in for dyno testing and we cannot even perform one safe pull. You can play with jetting all day and it won't make a difference. Something is messed up with the metering blocks and I have never looked into as time is $$$. J.Rob p.s. I bet if you put a regular and known good double pumper on you would see what you have been missing out on. No reason to change carbs as I'm not missing out on anything. I couldn't expect the car to run any better than it does. I also know someone running an 870 Avenger on their car and it's the same thing, no issues at all right out of the box. And yes, I do buy lottery tickets. No luck so far.
[Re: RAMM]
#2577126
11/11/18 02:54 PM
11/11/18 02:54 PM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
I have never and I mean NEVER seen one of those carbs run correctly. Avoid. J.Rob Are you referring to just the 670 version or any Street Avenger carb.? I have had a 770 Street Avenger on my car for nine years and it has run perfectly from day one. I hope you buy lottery tickets because I have never seen ANY Avenger series carb run properly. In fact I have had many come in for dyno testing and we cannot even perform one safe pull. You can play with jetting all day and it won't make a difference. Something is messed up with the metering blocks and I have never looked into as time is $$$. J.Rob p.s. I bet if you put a regular and known good double pumper on you would see what you have been missing out on. Sounds exactly like the issues with the Edelbrock 1407/1411 carbs Why waste your time playing with those two carbs when there are so many better options out there
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: 440mopar]
#2580279
11/19/18 05:38 PM
11/19/18 05:38 PM
Posts: 5,435 So Cal
Sinitro
So Cal
IMHO... There is no such thing as a perfect carburetor...Every engine is different (compression, intake manifold, cam specs) and it takes patience and experience to dial the carburetor in. A Holley is very simple to tune, its just isolating the problem area and then making the appropriate tweaks... To me the basic problem today is that there are fewer & fewer experienced guys with carburetor experience.. Just my $0.02...
[Re: 440mopar]
#2580315
11/19/18 08:04 PM
11/19/18 08:04 PM
Posts: 5,155 CT
GTX MATT
CT
I had a 770 SA on a 440 that pulled only about 7 inches of vacuum at 1000 RPM. Straight leg boosters and all, the fuel curve actually worked well, better than alot of other Holleys. Needed to be a little extra rich for best power at WOT (11.8ish), but the car ran decent.
[Re: Sinitro]
#2580323
11/19/18 08:30 PM
11/19/18 08:30 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
IMHO... There is no such thing as a perfect carburetor...Every engine is different (compression, intake manifold, cam specs) and it takes patience and experience to dial the carburetor in. A Holley is very simple to tune, its just isolating the problem area and then making the appropriate tweaks... To me the basic problem today is that there are fewer & fewer experienced guys with carburetor experience.. Just my $0.02... So true........
[Re: dogdays]
#2580331
11/19/18 08:53 PM
11/19/18 08:53 PM
Posts: 11,892 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
In a carb test run by Dunnuck a couple of years ago, the 670 Street Avenger was the farthest off and the most difficult to tune of the carbs they tested. The best was the Holley Street Demon. Nearly perfect out of the box, IIRC. For some reason the 670 is the red headed stepchild of the Street Avenger series. My 570 was up 2mpg over the Holley 1850 that had been jetted down for altitude. It was a really good carb.
The Street Demon with the space age plastic bowl is reminiscent of a Thermoquad, and is probably the latest design you can find. It will bolt on your square bore intake with no adapter. They don't cost too much, either.
R. The Street Demon is the $hit. At least for street cars. Has worked very well on every street combo that I have installed one on so far. Getting ready to put one on another 440 soon.
Master, again and still
