MP stage v head ? #2576336
11/09/18 02:09 PM
11/09/18 02:09 PM
moparx Offline OP
moparx  Offline OP
what size intake ports do these heads have ? max wedge size ? TIA as always. bow
beer
Re: MP stage v head ? [Re: moparx] #2576338
11/09/18 02:10 PM
11/09/18 02:10 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Std size.
Re: MP stage v head ? [Re: moparx] #2576341
11/09/18 02:14 PM
11/09/18 02:14 PM
AndyF Offline
AndyF  Offline
The old stage V heads were basically a cast iron 452 head with some minor modifications. It has been a long time since I looked at a set of those. I think Mopar added a little wall thickness in some areas but that was about it.
Re: MP stage v head ? [Re: AndyF] #2576353
11/09/18 02:31 PM
11/09/18 02:31 PM
moparx Offline OP
moparx  Offline OP
andy, these are aluminum heads. part # is : 4532134 [but the 3's may be 8's ?]
beer
Re: MP stage v head ? [Re: moparx] #2576355
11/09/18 02:34 PM
11/09/18 02:34 PM
AndyF Offline
AndyF  Offline
I don't recall a Mopar aluminum Stage V head. Stage VI was an aluminum head.
Re: MP stage v head ? [Re: moparx] #2576364
11/09/18 02:46 PM
11/09/18 02:46 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
Stage V = Iron
Stage VI = Aluminum
Re: MP stage v head ? [Re: moparx] #2576367
11/09/18 02:49 PM
11/09/18 02:49 PM
So. Burlington, Vt.
So. Burlington, Vt.
I have a set of “standard”(original style, raised std port) stage 6’s here that have that casting number.
The “part number” for them is P4529335.
Not including the Chapman stage 6’s, there are 4 different versions of the stage 6.
-Original stage 6(raised std port, straight plugs)
-MW stage 6 with angled plugs(raised MW port, small kidney shaped chamber, needs .485 offset intake rocker)
-MW stage 6 with straight plugs(MW raised port, std heart shaped chamber, straight plugs, .485 offset intake rocker)
-street stage 6(later called the aluminum commando head, non-raised std intake ports, straight plug)
Re: MP stage v head ? [Re: AndyF] #2576373
11/09/18 02:59 PM
11/09/18 02:59 PM
moparx Offline OP
moparx  Offline OP
here are a couple of pics. maybe i don't know what i'm talking about. [wouldn't be the first time ! laugh2] i shoulda done this in the first place.
beer
Re: MP stage v head ? [Re: fast68plymouth] #2576378
11/09/18 03:03 PM
11/09/18 03:03 PM
moparx Offline OP
moparx  Offline OP
fast, how can i tell what these are ? they have 2.250 intake & 1.8[?] exhaust valves.
beer
Re: MP stage v head ? [Re: moparx] #2576388
11/09/18 03:17 PM
11/09/18 03:17 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
They certainly look like the basic Stage VI w/ the RB intake spacers. The Crane rockers are standard-offset, and it's a standard M1 intake in the pics, so that should rule out being a MW version.
Stage VI seat inserts are borderline wide enough for even a 2.19" valve; can't see a 2.25" fitting w/o replacing the inserts. Even then, those ports aren't likely going to benefit from a valve that size as small as they are.
Re: MP stage v head ? [Re: fast68plymouth] #2576391
11/09/18 03:21 PM
11/09/18 03:21 PM
Washington
madscientist Offline
Washington
-MW stage 6 with straight plugs(MW raised port, std heart shaped chamber, straight plugs, .485 offset intaker rocker)
I've done several sets of the Stage VI MW angle plug heads. They are a giant PITA to make work, but they can make power.
They suck to port for sure.
Re: MP stage v head ? [Re: moparx] #2576392
11/09/18 03:22 PM
11/09/18 03:22 PM
So. Burlington, Vt.
So. Burlington, Vt.
As Brad said, std port intake on spacers on an RB block, std offset rockers and straight plugs = original stage 6.
And ditto on the seats.
The heads only come with intake seats that are 2.187”........ and don’t go very deep.
If they haven’t been replaced already, they need to be.
Re: MP stage v head ? [Re: fast68plymouth] #2576393
11/09/18 03:24 PM
11/09/18 03:24 PM
Washington
Washington
Why Chrysler used seas like that I have no idea. They did it on the W-5 heads too. The first step on heads like that is a seat replacement with a quality ductile iron seat.
Re: MP stage v head ? [Re: moparx] #2576398
11/09/18 03:33 PM
11/09/18 03:33 PM
So. Burlington, Vt.
So. Burlington, Vt.
Re: MP stage v head ? [Re: moparx] #2576400
11/09/18 03:34 PM
11/09/18 03:34 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
VI, or 6.
The visible number is the raw casting number, Last sold as machined/packaged P4529335.
Originally std. port window. Could be almost anything now, though.
https://board.moparts.org/ubbthreads/ubbthreads.php/ubb/showflat/Number/5240324/site_id/1#import
https://board.moparts.org/ubbthreads/ubbt...html#Post323080
Rich H.
Esse Quam Videri
Re: MP stage v head ? [Re: fast68plymouth] #2576408
11/09/18 03:44 PM
11/09/18 03:44 PM
Washington
Washington
LOl I remember that thread
Re: MP stage v head ? [Re: madscientist] #2576419
11/09/18 04:07 PM
11/09/18 04:07 PM
moparx Offline OP
moparx  Offline OP
thanks guys ! i am looking at this engine for use in my charger. it's a 500", and seems to have reasonable parts. was thinking to replace the intake with an original, 62 MW intake and carbs. then, just a general refresh on the block. has an A&A trans with a RMVB, an aluminum drum setup, and 5 pinion planetaries included. available 3500 converter plus other parts.
wife and i need a good day trip, and this is only 100mi away. owner has no problem tearing apart for a look see.
beer
Re: MP stage v head ? [Re: moparx] #2576424
11/09/18 04:15 PM
11/09/18 04:15 PM
So. Burlington, Vt.
So. Burlington, Vt.
You’d still need to use the spacer plates with the x-ram intake, and without the heads and spacer opened up to MW size, there will be a pretty sizable port mismatch.
I had a customer who wanted to do the same thing intake wise, really just for the looks........ I just opened up a set Stealths.
The report I got was it worked fine.
Re: MP stage v head ? [Re: moparx] #2576478
11/09/18 06:02 PM
11/09/18 06:02 PM
AndyF Offline
AndyF  Offline
Stage VI heads have a variety of well known problems but some of them worked just fine. If it was me I'd look for evidence of any water leaks. See what the plugs and ports look like. Even if it ran great for the current owner the heads might develop a problem for you. Could still be a good deal if the price is right.
Re: MP stage v head ? [Re: AndyF] #2576778
11/10/18 02:13 PM
11/10/18 02:13 PM
moparx Offline OP
moparx  Offline OP
i can't quite make out the number on those rockers. are they needle bearings or bushed ?
beer
