Hemi aluminum bell housing - first year ? #2573753
11/04/18 05:06 AM
11/04/18 05:06 AM
A727Tflite Offline OP
When did Ma Mopar go to aluminum bellhousings - on Hemis.
How about on big blocks?
Any issues with them, cracking, etc.
Re: Hemi aluminum bell housing - first year ? [Re: A727Tflite] #2573786
11/04/18 10:25 AM
11/04/18 10:25 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
1970. Yes I’ve seen cracks but not that common. Big blocks and hemi used same one in 70.
Re: Hemi aluminum bell housing - first year ? [Re: fastmark] #2573801
11/04/18 11:23 AM
11/04/18 11:23 AM
Thanks for the reply.
Re: Hemi aluminum bell housing - first year ? [Re: A727Tflite] #2573870
11/04/18 01:58 PM
11/04/18 01:58 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
Most common crack is thru a bolt hole to the hole the clutch fork comes thru. Have seen a few but not common, and its usually thru the starter bolt hole, so maybe overtightened, or crossthreaded who knows.
Re: Hemi aluminum bell housing - first year ? [Re: A727Tflite] #2573878
11/04/18 02:20 PM
11/04/18 02:20 PM
DELAWARE
TONY_DAGOSTINO Offline
DELAWARE
be sure to use a steel inspection cover, it gives rigidity to the bellhousing
Re: Hemi aluminum bell housing - first year ? [Re: A727Tflite] #2573971
11/04/18 05:20 PM
11/04/18 05:20 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Personal experience using aluminum bell housing, back in the day, I felt, the inspection cover off, or lost it, the fly wheel picked up a rock that put a big hole in the top of the bell housing.
Re: Hemi aluminum bell housing - first year ? [Re: A727Tflite] #2575998
11/08/18 06:52 PM
11/08/18 06:52 PM
Chicago
PurpleBeeper Offline
Chicago
Unless you're trying to lighten the car, I personally don't like the aluminum bellhousings. The one I ran for about 3-4 months cracked big time from street racing. Tony's idea of running a steel inspection cover sounds like a good one if you plan to run one.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: Hemi aluminum bell housing - first year ? [Re: A727Tflite] #2576000
11/08/18 07:01 PM
11/08/18 07:01 PM
It’s an original car so I want to retain the originality.
And yes, the presence of an inspection cover definitely adds rigidity to the bell.
Re: Hemi aluminum bell housing - first year ? [Re: A727Tflite] #2576246
11/09/18 09:18 AM
11/09/18 09:18 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Then aluminum it is!
