Re: A12 Butterscotch question
[Re: MI_Custumz]
#2576369
11/09/18 02:51 PM
11/09/18 02:51 PM
Posts: 5,106 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
Friend of mine owned a 1969 RT Coronet 440 four speed Dana in this color. I used to have pictures of the car but once he sold it I ended up giving the new owner all my pictures. It was bought new in the USA I think Ohio and brought to Ontario, Canada about 25 years ago and might be still in Canada.
1971 HEMI E BODY REGISTRY
[Re: SuperRob]
#2576377
11/09/18 03:02 PM
11/09/18 03:02 PM
Posts: 9,407 Brantford Ontario
69_SIX_PACK
Brantford Ontario
Thanks for the story Mike. Do you know what happened to the Butterscotch A12 Bee with the red stripe that was for sale some years ago? Somehow I really liked that odd combo. Was tan interior 4-speed too, iirc. Its in Alberta now. Dave
[Re: 69CoronetRT]
#2576647
11/10/18 02:00 AM
11/10/18 02:00 AM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
Paint code 96 is Butterscotch on a Super Bee. I don't think you will find 96 on other Dodges.
If the Dart pictured is car 3443**, it codes 99 NOT 96. Therefore it may be Butterscotch in color but it does not code 96. It codes for special order paint. If the color was released for Darts, one would expect to fine examples pop up now and then.
So what you are saying is that Plymouth used the 96 code and Dodge would have used the 99 code. Is that correct? Because I encountered a 69 Charger 383 4 speed that was this color back in 1981
[Re: Morty426]
#2576696
11/10/18 09:27 AM
11/10/18 09:27 AM
Posts: 5,645 Port Huron, Michigan
MI_Custumz
So what you are saying is that Plymouth used the 96 code and Dodge would have used the 99 code. Is that correct? Because I encountered a 69 Charger 383 4 speed that was this color back in 1981 96 is Butterscotch, 99 is special order and could be Butterscotch or any other special order color. Butterscotch is Dodge, Bahama Yellow is Plymouth.
[Re: MI_Custumz]
#2577026
11/11/18 05:13 AM
11/11/18 05:13 AM
Morty426
Sacramento CA
So what you are saying is that Plymouth used the 96 code and Dodge would have used the 99 code. Is that correct? Because I encountered a 69 Charger 383 4 speed that was this color back in 1981 96 is Butterscotch, 99 is special order and could be Butterscotch or any other special order color. Butterscotch is Dodge, Bahama Yellow is Plymouth. Sorry - I should have said "So a non-Superbee Dodge would have used a 99 paint code?"
