Re: Full Rewiring
[Re: 70charger512]
#2575172
11/07/18 02:46 AM
11/07/18 02:46 AM
Posts: 18,157 Mass
DAYCLONA
Mass
I replaced EVERY harness front to back in my 70 Charger with M&H's repro harnesses, the only used factory harness I have in the car is the power window set up that I added and a NOS factory steering column harness, and only because those items weren't available from M&H, last thing I want in any restored car is a 40-50 yr old harness(es)...
I'd recommend M&H, my Charger was retrofitted 14 yrs ago, ZERO issues with electrical to date...
Your looking at about $1500+ in harnesses from M&H to rewire the car if you go that route, with the dash being the most expensive, but the other harnesses will quickly add up, I ordered everything thru Year One, the only licensed supplier at the time...
Mike
Re: Full Rewiring
[Re: 70charger512]
#2575174
11/07/18 02:50 AM
11/07/18 02:50 AM
Posts: 1,317 Ohio
jlatessa
Ohio
I Know a lot of guys like the plug-n-play types, but For a lot less money and a good way to learn about your 70's systems, I used the Painless kit.
It is doable for the hobbyist and you can ensure all your connections are solid with the proper crimping tools.
Also it gives you the option of soldering ALL the high current terminals.
With their instructions and a good color MOPAR schematic, you will understand better the workings of your system.
My 2 cents....Joe
PS. It doesn't use the firewall bulkhead, has a good main fuse system and allows a better ammeter solution.
Re: Full Rewiring
[Re: 70charger512]
#2575191
11/07/18 03:58 AM
11/07/18 03:58 AM
Posts: 623 Zombieland
Car Nut
Zombieland
M&H wiring - dash, rear lights, forward light wiring and engine harness best plug and play sold through Yearone, wait for their 30% off sales. American Auto wiring - a good aftermarket if you want to upgrade, but not factory, so no bulkhead plug. https://www.americanautowire.com/
Re: Full Rewiring
[Re: DAYCLONA]
#2575193
11/07/18 04:24 AM
11/07/18 04:24 AM
Posts: 257 NC
70charger512
#1 Thread Starter
#1 Thread Starter
NC
Mike Thats what i have heard, so with the m&h harnesses, i can replace every bit of wiring (except the power window and steering column harness)? Ill give them a call tomorrow about exactly what i need, thank you very much. Also, how would i go about keeping the aftermarket radio and rear speakers (the rear speakers are enough the fronts are shot anyways)?
Re: Full Rewiring
[Re: 70charger512]
#2575254
11/07/18 12:14 PM
11/07/18 12:14 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Mike Thats what i have heard, so with the m&h harnesses, i can replace every bit of wiring (except the power window and steering column harness)? Ill give them a call tomorrow about exactly what i need, thank you very much. Also, how would i go about keeping the aftermarket radio and rear speakers (the rear speakers are enough the fronts are shot anyways)? M&H has updated/added a lot more harness and options over the years, plus if you have a harness (in good shape) that they don't offer, and they express interest in it, they will use it as a model for reproducing one for you and future customers... As far as the aftermarket radio/speakers, if your not comfortable wiring your own system into the factory harness, have a professional stereo shop install it...
Re: Full Rewiring
[Re: krautrock]
#2575306
11/07/18 01:49 PM
11/07/18 01:49 PM
Posts: 348 Texas Hill Country
Centerline
Texas Hill Country
50 year old wiring is an invitation for failure or worst case a fire. Its a safety concern.
I rewired my '64 Polara with a 20 circuit aftermarket kit because I don't have the kind of money it takes to use a reproduction harness. Aftermarket kits are all high quality and you learn a lot about how your 50 year old electrical system works if you do it that way. That said, if you don't have the ability or you're doing a concourse restoration, then an expensive reproduction harness would be the way to go.
Centerline 64 Dodge Polara 426 Street Wedge - For when I want to go fast 99 Corvette Z-06 - For when I want to turn corners
Re: Full Rewiring
[Re: 70charger512]
#2576142
11/09/18 12:53 AM
11/09/18 12:53 AM
Posts: 43,115 Bend,OR USA
Cab_Burge
If you don't have a OEM type factory service manual, not a Motors or Chilton service manual then buy one now. Mopar is great on their FSM on all the electrical circuits and diagrams Mopar has done some mid year changes like the 1969 1/2 390 HP 440 6 pack motors with the wiring needed for the idle shut off solenoid that weren't in the original 1969 FSM for both the Dodge and Plymouth B bodies I'm not sure if you can still get copies of the update to the FSM or not for changes like that. I have done several complete restorations on mid 1960 to early 1970 Mopar B,E and A body cars, all of the factory wiring harnesses are plug and play I need to let you know I worked for a telephone company for over 30 years in customer services fixing telephones and telephone lines so low voltage direct current electrical issues do not scare or mystified me. Nothing for you to worry about either
Re: Full Rewiring
[Re: Cab_Burge]
#2576567
11/09/18 10:35 PM
11/09/18 10:35 PM
Posts: 257 NC
70charger512
#1 Thread Starter
#1 Thread Starter
NC
If you don't have a OEM type factory service manual, not a Motors or Chilton service manual then buy one now. Mopar is great on their FSM on all the electrical circuits and diagrams Mopar has done some mid year changes like the 1969 1/2 390 HP 440 6 pack motors with the wiring needed for the idle shut off solenoid that weren't in the original 1969 FSM for both the Dodge and Plymouth B bodies I'm not sure if you can still get copies of the update to the FSM or not for changes like that. I have done several complete restorations on mid 1960 to early 1970 Mopar B,E and A body cars, all of the factory wiring harnesses are plug and play I need to let you know I worked for a telephone company for over 30 years in customer services fixing telephones and telephone lines so low voltage direct current electrical issues do not scare or mystified me. Nothing for you to worry about either I do have a service manual actually, you can download them for free from mymopar.com. I have it on my laptop and phone, I don't believe I'd have to worry about mid year changes or anything like that. Also, if I plan on swapping the 727 to an aftermarket manual, should I get the manual harnesses?
Re: Full Rewiring
[Re: 70charger512]
#2576623
11/10/18 01:18 AM
11/10/18 01:18 AM
Cab_Burge
The tranny wiring harnesses are different for the 727 versus NP 833 so yes buy the one you need for the backup lights and if you want to use the clutch pedal safety starter circuit for your car buy the switch and wiring harness for the clutch pedal and install them at the same time
Re: Full Rewiring
[Re: 70charger512]
#2577016
11/11/18 03:40 AM
11/11/18 03:40 AM
Cab_Burge
I can't answer your question on that tranny, call the manufacturer or one of their vendors and ask them if it has a back up light switch in it or not
