Didn't want to hijack that 1000hp hemi thread anymore than I already have.
last 2 quick builds I did were short block 68223196AB $2900,+ a set of Eagle heads (53021608DF $325 each) swap valve springs over to Psi 1515 (265 from speedlogix) Comp cams 270 VVt ($685---yes cams are too F--ing expensive.
Ritter Drag pak from MMX for $700 (short version) Comp pushrods $120
Short Block= $2900
Heads + vavle springs $1000
Cam $685
ATI 918487 Damper $379
5k out the door not including my labor($500) and shipping.
yes they need to buy their own front cover($50-250) and oil pan ($50-500).
Rockers/shafts/etc?
Valve covers?
ist build went into a Willys street rod, headers were custom, and he was having a friend machine valve covers for him. Rocker he provided they were Harland sharp, MSD Hemi-6 box and the rest I don't know.
2nd build went in to a 72 Road Runner clone, he traded me a 5.7 eagle engine for labor, but kept the rockers and valve covers from that engine, Headers are TTI 64L-R1C0 raw steel headers I think there were $700ish. he had started out with the MSD box but has since switched over the the Holly set up and an Edelbrock EFI intake.
William D , yes I have bought heads from Red line engine supply , I've also bought a few of their engine kits for other types of Engines.
