Re: 69 charger no power to turn/flash
[Re: stumpy]
#2574544
11/05/18 07:29 PM
11/05/18 07:29 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Sounds to me like you have isolated the trouble to the switch. Get a replacement from the parts store and just plug it in before installing it to try it. That way you aren't having to tear apart the column and if it doesn't fix the issue just return the switch. Agreed, common problem on B bodies, just that I'd double check the wiring on the new switch with the FSM wiring diagram before plugging it in, some of the aftermarket switches have terminal feeds in the wrong pin location, as they are for other applications at times, and it never fails that your application isn't one of them, I've had this happen on a few aftermarket turn signal switches, Mopar and GM... it's easy enough to move the wires in the plug end by depressing the tang that holds it in the plastic pin housing, removing it and swapping it out in the desired order Mike
[Re: pullandrag]
#2574626
11/05/18 10:25 PM
11/05/18 10:25 PM
Posts: 531 Charlotte, NC
Kowal
Charlotte, NC
Had the same problem on my GTX. The switch fixed it.
But...I did an aftermarket switch first and that didn’t fix it, splicing the wires. Found a NOS piece and it worked, so not sure what happened. I did check the connector (might be a good thing to check).
'69 Hemi Charger 500, ‘70 U code Challenger R/T (These and a bunch others at www.dkowal426.com) P.J. O'Rouke: "The old car ran perfectly, right up until it didn't."
[Re: pullandrag]
#2574641
11/05/18 11:04 PM
11/05/18 11:04 PM
Posts: 2,853 Pattison Texas
CSK
Pattison Texas
year one has the correct, works great turn signal switch
[Re: CSK]
#2574804
11/06/18 12:59 PM
11/06/18 12:59 PM
RapidRobert
If you ain't already taken it out (TS switch) you might ohm it in the 3 positions & see if the continuities at the pull apart connector are correct. white is power in from the brake light switch & with the stalk in neutral there should be continuity to the (2) out wires to the dr/pass large filaments in the rear 1157 bulbs & you could go behind the dr kick panel & jump fire there to see if everything rearward from that point is good (or not). www.mymopar.com has wiring diagrams. I hear they ain't 100% complete in some apps but for a bare bones 69 you should be good.
[Re: pullandrag]
#2575022
11/06/18 08:32 PM
11/06/18 08:32 PM
RapidRobert
No it was my mistake, the white power in from the brake pedal switch will only be hot when the pedal is pressed & with the stalk in the "middle" there should be power out to the R/L rear brake light large filaments. In other words the brakes functioning normally like they should with no TS interaction cuz you ain't making a turn.
[Re: pullandrag]
#2575270
11/07/18 12:35 PM
11/07/18 12:35 PM
RapidRobert
Robert gotcha,didn't get out there tonight either but I'll post back for sure thanks very much again,I see your in Lincoln I came up 77 went up to Wahoo to drop some implements accidentally went through the city instead of around. Your town isn't for Kansas dummy's! Actually I grew up in Kansas! (Parsons) & settled in Lincoln (for the most part) decades ago after drifting around the country for a few years after I got out of the Army. Lincoln ain't bad exc in rush hour. Violent crime is on the increase here (like everywhere), drugs/mental health issues. I dont know the basics of that system real well & I would definitely check what Ron said.
[Re: pullandrag]
#2575626
11/07/18 11:55 PM
11/07/18 11:55 PM
Posts: 10,528 Freeport IL USA
poorboy
Freeport IL USA
Sometimes these things are pretty irritating. Through the years, Chrysler has changed the color of the wires at terminal ends. One color on one side of the connector, and a different color connects to it on the other 1/2 of the connector. I believe it probably has a lot to do with who supplied the specific harness, and the color could have changed during a model year, or after a model year. It can make things pretty complex. About the only thing you can do is use an Ohm meter and check the column harness to see where each wire ends up on the switch itself. You will need to make a diagram you understand, so you know how to orientate it to the other connector. Then label each wire on your diagram as to where it goes. Hopefully the wires in the column harness are in the correct location in the connector as the wires that match the correct color on the wiring diagram you are using. As much of a pain as that is, its probably the only way to get it right.
I have a lot of wiring experience. Don't let this get you down, sometimes its hard for the seasoned guys as well. I'm messing with a Mopar cruise control system for my old car. The factory cruise functioned pretty much the same for several years. The wiring I have available between the servo, the brake switch, and the off/on/resume and set switch uses different color wires at every connection. To make things even more fun, one connection has 4 wires, and its mate has 4 wires, both parts use the same 4 colors for the wires on both sides of the connector, but each color has a different function on the other end of the connector. The wires are (or were, I won't say who may have messed them up) in the correct location in the connector, but the white wire does not connect to the white wire, it connects to a blue wire. The other blue wire connects to a yellow wire, The other yellow wire connects to, well, you get the idea. To make matters worse, neither group of color wires did the same function as the matching color of wires in the wiring diagram I was using. After I finally figured out the wiring harness, I had 3 bad switches in a row. The cruise still does not function, after the bad switches, I decides I didn't need cruise right now.
Good luck with your turn signal switch. Gene
