Re: Dana 60 - where to get? [Re: MarkZ] #2608564
01/18/19 01:51 PM
01/18/19 01:51 PM
AndyF Online content
AndyF  Online Content
Looks good. Did you have a local shop narrow it and move the perches in?
Re: Dana 60 - where to get? [Re: AndyF] #2608675
01/18/19 05:22 PM
01/18/19 05:22 PM
MarkZ Offline OP
Worthy
MarkZ  Offline OP
Worthy
Yeah, Warren Gear and Axle in Warren, Michigan. Considering I dropped everything off right before between Christmas and New Years they turned it around pretty quickly.
It'll probably be a month or so before I make anymore headway on it. My garage isn't heated and it's supposed to get colder. Gives me time to save I guess.
Re: Dana 60 - where to get? [Re: MarkZ] #2608712
01/18/19 06:41 PM
01/18/19 06:41 PM
Just need to make some brake lines and then get it in the car. You'll have to fabricate something for the e-brake also. Will you have any clearance issues with the exhaust or the gas tank?
Re: Dana 60 - where to get? [Re: MarkZ] #2608926
01/19/19 11:33 AM
01/19/19 11:33 AM
Virginia
larry4406 Offline
larry4406  Offline
Virginia
Those Explorer discs look nice. What modifications if any are needed to run those? How does an emergency brake work (internal drum hat)?
Re: Dana 60 - where to get? [Re: MarkZ] #2608975
01/19/19 02:03 PM
01/19/19 02:03 PM
MarkZ Offline OP
Worthy
MarkZ  Offline OP
Worthy
@AndyF: I don't think I'll have any issues with the exhaust since the tubes are the same diameter as the 8.75", but I have my fuel pump and filter mounted to an aluminum plate in front of tank. It fit just fine with the 8.75". Won't find out if that is going to be an issue until I go to install it in the car. I have a custom tank on the list of things to do this season. Might have to happen sooner than later.
@Larry: Need to use Ford housing ends on the axle to get them to bolt on. Since it needed new ends anyhow it wasn't any additional cost. Yeah, e-brake is under the rotor hub. I don't know what is going to be involved with the e-brake cables yet as it isn't in the car. There are a few guys here that have used this exact kit in their cars though.
Re: Dana 60 - where to get? [Re: MarkZ] #2608988
01/19/19 02:35 PM
01/19/19 02:35 PM
There are several places that make E brake cables for those Ford brakes. Those are popular brakes with street rod guys so you can find the cables without any issue. Doctor Diff can get you cables too.
Re: Dana 60 - where to get? [Re: AndyF] #2609000
01/19/19 03:04 PM
01/19/19 03:04 PM
MarkZ Offline OP
Worthy
MarkZ  Offline OP
Worthy
That's good to know. After the axle is installed I need to call Cass back for a master cylinder and 11.75" rotors for the front (already have the caliper adapters). Thanks again for all the help.
Re: Dana 60 - where to get? [Re: MarkZ] #2609431
01/20/19 06:19 PM
01/20/19 06:19 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
The only better Ford brake setup is off the newer crown vic's that will work on a 60, they have vented rotors that are almost 7/8" thick...but the bearings and ends are slightly smaller than the explorer and are only available from the salvage yards so not as common. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
