Re: Dana 60
[Re: cdwmotorsports]
#2574430
11/05/18 03:16 PM
11/05/18 03:16 PM
Posts: 20,154 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Wow!!!! Somebody needs a Snickers Bar. 😂
Re: Dana 60
#2574436
11/05/18 03:24 PM
11/05/18 03:24 PM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
Also unless you're going to fund my build I don't care that you would use a 9" Ford over a Dana, or a Glide over a 727. Have a great day. Good answer. How about an 8-3/4"?
Re: Dana 60
[Re: DrCharles]
#2574449
11/05/18 03:44 PM
11/05/18 03:44 PM
Posts: 20,154 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Also unless you're going to fund my build I don't care that you would use a 9" Ford over a Dana, or a Glide over a 727. Have a great day. Good answer. How about an 8-3/4"? I hear the 7 1/4 rearends are lighter and cheaper
Re: Dana 60
[Re: an8sec70cuda]
#2574494
11/05/18 05:30 PM
11/05/18 05:30 PM
Posts: 5,161 CT
GTX MATT
CT
They will most likely come w/ either 4.10 or 3.54 gears and hopefully you'll get the good powerlock diff. What years/applications used the powerlock? I haven't been able to figure that one out
Re: Dana 60
[Re: DrCharles]
#2574581
11/05/18 08:58 PM
11/05/18 08:58 PM
Posts: 2,104 Byron, NY
W.I.N. Racing
Byron, NY
Also unless you're going to fund my build I don't care that you would use a 9" Ford over a Dana, or a Glide over a 727. Have a great day. Good answer. How about an 8-3/4"? X2 minus the 8-3/4 part
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Dana 60
[Re: GY3]
#2575409
11/07/18 04:21 PM
11/07/18 04:21 PM
Posts: 13,354 Marion, South Carolina [><]
an8sec70cuda
Yes, the smaller axle tubes will make it easier to use the 8 3/4 shock plates and u-bolts. Mine had the 3.25" tubes and took some convincing to get the u-bolts on. NAPA has U bolts for the 3.25" axle tubes and they fit right through a factory Mopar shock plate w/ no grinding.
Re: Dana 60
[Re: J_BODY]
#2575614
11/07/18 11:44 PM
11/07/18 11:44 PM
Posts: 20,154 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I prefer the side adjusters on the S60 over the shims of a D60.... and the 8.75+.25 is a great direction to go. Shhhhhh unless you are going to buy it for him he wants to do it his way. With a non Mopar Dana Corporation rearend.
Re: Dana 60
[Re: pittsburghracer]
#2575706
11/08/18 02:59 AM
11/08/18 02:59 AM
Posts: 3,517 pacific northwest
Stroker Scamp
pacific northwest
Make sure not to pick up one that is the heavy duty like I did, It has two ribs by the cover. Way too heavy
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip 73 Duster 340 street strip 12.79 @ 105
Re: Dana 60
#2575785
11/08/18 11:29 AM
11/08/18 11:29 AM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
Is there any reason why I couldn't cut down a Dana 60 from a Dodge truck to replace my 8.75. I am wanting to us that 8.75 in another A-body and figure if I can get a housing bought cheap I might just start there. What year truck should I look to get one from? What's a good price on a housing? If you want cheap look at the 9 1/4 rears. Don't know what you plan on using it for but around here they are dirt cheap. Don't know why they haven't taken off in the aftermarket? As for the Dana 9 inch debate it's been done to death.
Re: Dana 60
[Re: MattW]
#2575910
11/08/18 03:17 PM
11/08/18 03:17 PM
Posts: 43,115 Bend,OR USA
Cab_Burge
Is there any reason why I couldn't cut down a Dana 60 from a Dodge truck to replace my 8.75. I am wanting to us that 8.75 in another A-body and figure if I can get a housing bought cheap I might just start there. What year truck should I look to get one from? What's a good price on a housing? If you want cheap look at the 9 1/4 rears. Don't know what you plan on using it for but around here they are dirt cheap. Don't know why they haven't taken off in the aftermarket? As for the Dana 9 inch debate it's been done to death. I think the crush sleeve and taper axle housing and gear selection has made them not popular
Re: Dana 60
[Re: dvw]
#2576242
11/09/18 09:06 AM
11/09/18 09:06 AM
Posts: 695 Southern Alberta
Uberpube
Southern Alberta
No way I'd use a Dana 44. 8.5" ring gear. Doug The Jeep dana 44 hd has an 8.9" ring gear, and the pinion shaft is same size as Dana 60.
