Socket for dome light? #2570591
10/28/18 02:18 PM
10/28/18 02:18 PM
West Plains, MO
DrCharles Offline OP
West Plains, MO
Does anyone have a part number for a socket (and bulb) that will fit my '72 Swinger's dome light? work
I have a good chrome base and plastic lens, just need a pigtail socket that will clip in the hole. Not having much luck searching. Thanks.
Re: Socket for dome light? [Re: DrCharles] #2570604
10/28/18 03:02 PM
10/28/18 03:02 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
You'll need a dual-contact single element socket with straight-across pins, you might find something here that fits your hole size:
https://www.taillightking.com/light_bulbs_Sockets.htm
Re: Socket for dome light? [Re: DrCharles] #2570625
10/28/18 03:52 PM
10/28/18 03:52 PM
West Plains, MO
West Plains, MO
Thanks for that link, I'm looking through that table now smile
Isn't the original bulb a #67 (which is a bayonet base, single contact with a small envelope)? The socket needs two wires though, since neither is grounded (one supplies +12, the other is grounded through the door jamb switches). So it'll probably be a plastic snap-in type.
Re: Socket for dome light? [Re: DrCharles] #2570672
10/28/18 06:11 PM
10/28/18 06:11 PM
West Plains, MO
West Plains, MO
Got tired of searching unsuccessfully... so I mounted the socket formerly used in the steering column on a 1/4" standoff insulator. The return wire is soldered to the socket stamping.
I even had a suitable #431 bulb handy (3.5 watts) that fits the miniature bayonet socket, close enough to original dome light specs cool
