Re: Trick Flow manifold and hood clearance B body
[Re: frank]
#2569740
10/26/18 01:31 PM
10/26/18 01:31 PM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
Years ago I had a 68 Charger with 400/451 stroker and Indy heads and intake, with a dominator under the stock hood. I would think the Indy intake is at least as tall as TF intake, if not taller. Mine was more of a race car and I did not have an air cleaner on it, but everything did fit under the hood. Not too much clearance though. If you're using a 4150 carb and the TF intake is a little shorter than Indy's, it just might fit w an aircleaner. You might also try the shorter filter element with a drop base and also k and n flow top.
2 kids and a dog
[Re: frank]
#2569746
10/26/18 01:43 PM
10/26/18 01:43 PM
Posts: 30,947 Oregon
AndyF
I had to cut a hole in the hood of my B body to clear the Trick Flow intake but I'm using a 4 inch tall air cleaner.
[Re: hudsonhornet7x]
#3036832
04/25/22 09:01 AM
04/25/22 09:01 AM
Posts: 1,314 Ohio
jlatessa
Ohio
How does a Trick flow compare in height to a Edelbrock 6bbl?
They fit under a 70 stock hood with a standard air cleaner. On a RB, too
Joe
