Radio Help #2568504
10/23/18 06:46 PM
10/23/18 06:46 PM
Milan Ohio
ct440rod Offline OP
ct440rod  Offline OP
Milan Ohio
I bought a radio for 70 challenger many years ago and just got around to work on it. I was going to see if it worked before I spent a lot of time putting new wires and ends on. Been so long I forget what the knobs do. I think left inside is volume and left outside controls tone. right inside is tune but I forgot what right outside does.
Re: Radio Help [Re: ct440rod] #2568623
10/23/18 10:21 PM
10/23/18 10:21 PM
front/rear speaker balance? (Just guessing).
Re: Radio Help [Re: ct440rod] #2568676
10/24/18 12:32 AM
10/24/18 12:32 AM
Alabama
BigMoneyLewis Offline
Alabama
If you have a 1970 knob style radio then it is an AM , and therefore the right inner knob turns along with the outer knob , Bendix radio, rh shaft is a one piece used for tuning only.
If you have an AM FM with knobs, then you have either a 1972-74 radio or
something other than E body. In which case, if it is stereo and not mono, the
RH inner knob does control the left/right balance.
Greg
gregward@mchsi.com phone 256-852-0955
Re: Radio Help [Re: BigMoneyLewis] #2568746
10/24/18 09:49 AM
10/24/18 09:49 AM
Milan Ohio
ct440rod Offline OP
ct440rod  Offline OP
Milan Ohio
Greg
you answered my second question. I was looking at radio last night and both right knobs turn together I thought they were stuck together. Now i know that is how it works . .
thanks
Gregg
Re: Radio Help [Re: BigMoneyLewis] #2569910
10/26/18 07:56 PM
10/26/18 07:56 PM
Milan Ohio
ct440rod Offline OP
ct440rod  Offline OP
Milan Ohio
If I have the radio on work bench and have 12 volts source and have speaker hooked up and only speakers hum's do I need to hook a antenna up to get anything ?
Re: Radio Help [Re: ct440rod] #2569939
10/26/18 08:54 PM
10/26/18 08:54 PM
North Pole,New York
formula_s Offline
formula_s  Offline
North Pole,New York
Yes, unless you're less than half a mile from a 50 kilowatt AM station.
https://radio-locator.com/cgi-bin/locate?select=city&city=milan+oh&x=11&y=5
Re: Radio Help [Re: ct440rod] #2570098
10/27/18 04:22 AM
10/27/18 04:22 AM
Washington
billyboo Offline
billyboo  Offline
Washington
If you have a hum that does not change with the volume control it has bad electrolytic caps. No antenna probably no sound or a hiss.
bill@billtheradioguy.com
Re: Radio Help [Re: ct440rod] #2570131
10/27/18 10:25 AM
10/27/18 10:25 AM
Milan Ohio
ct440rod Offline OP
ct440rod  Offline OP
Milan Ohio
Who has best price on radio knobs for 70 challenger AM
