Re: Slight water drip behind motor plate....What to do [Re: Sammy] #2567372
10/21/18 04:24 PM
10/21/18 04:24 PM
AndyF Offline
AndyF  Offline
Did you not have a gasket on the block side before? You need to use two sets of gaskets with the motor plate, one in front and one behind.
Re: Slight water drip behind motor plate....What to do [Re: AndyF] #2567374
10/21/18 04:27 PM
10/21/18 04:27 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
I put 2 pairs on the block side with RTV and 1 pair on the water pump side
For some reason 1 pair did not work on block side.
Re: Slight water drip behind motor plate....What to do [Re: Sammy] #2567696
10/22/18 09:49 AM
10/22/18 09:49 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I use no gasket at all. Just Ultra Grey RTV. No leaks in 6 years.
D2
Doug
