360 magnum max safe valve spring pressure #2567469
10/21/18 09:00 PM
10/21/18 09:00 PM
Nebraska
4406bbl Offline OP
4406bbl  Offline OP
Nebraska
What is safe with new original hydraulic roller lifters? Mild cam
550 lift, I have heard 350-360 pounds max. Anyone run more with no problems, or run less and had problems?
Re: 360 magnum max safe valve spring pressure [Re: 4406bbl] #2567543
10/21/18 11:31 PM
10/21/18 11:31 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
I ran mine at 370lbs and .550" lift. It wouldn't make as much RPM as I had hoped. So I shimmied the lifters to near solid (ONLY .025" of plunger travel), and put 440lbs springs on it. Didn't change a damn thing with the RPM...
That to me was a true test, meaning at 370lbs it wasn't floating a valve or collapsing the lifter.
