Main dowel for "World" block, source?
#2566972
10/20/18 04:36 PM
10/20/18 04:36 PM
Posts: 17,838 S.E. Michigan
ZIPPY
S.E. Michigan
I'm working with a used block that has a damaged dowel on one of the mains. Looks like 5/8 od. Anyone have a source other than Mitchell?
Rich H.
Esse Quam Videri
Re: Main dowel for "World" block, source?
[Re: RUNCHARGER]
#2566996
10/20/18 05:41 PM
10/20/18 05:41 PM
ZIPPY
S.E. Michigan
It's a hollow cylinder shape. (It's not a pin).
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2567488
10/21/18 09:42 PM
10/21/18 09:42 PM
Posts: 2,175 Duloc
The Shadow
Duloc
[Re: AndyF]
#2567574
10/22/18 12:16 AM
10/22/18 12:16 AM
Posts: 4,457 Washington
madscientist
Washington
Can you post a picture. If you know the OD, ID and length I bet you can find it. I doubt that some engineer designed a custom dowel for that application but you never know. Some wizard at Chrysler designed different throttle cables and throttle springs year after year even though they didn't really need them. Damn. Another AndyF post that made me LOL! Quoted for truth for sure.
[Re: The Shadow]
#2567790
10/22/18 12:51 PM
10/22/18 12:51 PM
ZIPPY
S.E. Michigan
Nope, now that I checked it..no workie....too big for the hole. Thank you for the idea, though. Would need to put it on a lathe, which is not out of the question. Waiting for the mc master 5/8 thinwall tubing, as long as the od is within spec it should do the trick.
[Re: ZIPPY]
#2567997
10/22/18 08:21 PM
10/22/18 08:21 PM
Posts: 2,175 Duloc
The Shadow
Duloc
Did you measure them? They should be oversize Unless the tube you get is slip fit it may be tough to install without damaging
[Re: ZIPPY]
#2568647
10/23/18 11:22 PM
10/23/18 11:22 PM
ZIPPY
S.E. Michigan
This will be super simple when I get a minute. Just needs maybe .001 polished off (optional, just to be same as the existing pieces), cut to length, bevel the ends, install.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2568882
10/24/18 02:02 PM
10/24/18 02:02 PM
ZIPPY
S.E. Michigan
Right, now that I've got enough to make a whole set, temptation is to replace them all for really no reason.
Rich H.
Esse Quam Videri
